| 225 Engine rebuild project https://slantsix.org/forum/viewtopic.php?t=23322 |
| Author: | eugenefelisco [ Thu May 24, 2007 8:12 am ] |
| Post subject: | 225 Engine rebuild project |
Greetings, I have a 1962 plymouth valiant that I want to restore. It has a 225 slant six and a push botton tranny. I want to ask everybodies help on this. I need some informations on valve lash, torque specs, firing order and electricals running from dash to engine. Is there a rebuild book or a manual I can buy out there. Please give me good link to it. This will be my first vintage rebuilt coz I'm very familiar with all japan imports like hondas,toyotas,nissans and mitsubishi engines from stock to outragious hp's for about 1300 hp at the wheels. So please help me on this. If someone needs my email its eugenefelisco@comcast.net or I can give you my phone if needed. Thank you very much any help will be appreciated. Eugene |
| Author: | eugenefelisco [ Thu May 24, 2007 8:32 am ] |
Oh I forgot to ask about how much will the parts goes. Like the piston rings, valve, valve guides, gaskets , fasteners(if I break one)and carb rebuild kits. Can someone give me a rough estimate on this. And I want to ask the availability of these parts in my local stores like Kragen and goodguys. Will this be a wise move to rebuild it from the ground-up or just buy a crete engine and swap it to her. |
| Author: | Matt Cramer [ Thu May 24, 2007 8:51 am ] |
Eugene, I highly recommend tracking down a factory service manual. Nothing else will have the same quality when it comes to wiring diagrams and other information. I think some of the others will chime in with sources for them. The mechanical parts are widely available, and I think you'll be pleasantly surprised at the prices. The push button Torqueflite has a few unique parts that are hard to find, but both the slant six and the 904 stayed in production for decades in one form or another, so replacement parts are pretty common. Unfortunately, the state of rebuilt parts out there is pretty bad, particularly carburetors but several other things too. It's gotten to the point where a teenager who's never worked on cars before has a better shot at rebuilding a carb correctly than the companies who supply auto parts houses with their rebuilt carbs. No exaggeration - I've done a comparison. You're much better rebuilding the parts you have now than going with a rebuilt engine from a parts store, if it even needs rebuilding. |
| Author: | MenkeMoose [ Thu May 24, 2007 8:54 am ] |
Welcome Eugene! As far as books go, see this thread:http://www.slantsix.org/forum/viewtopic.php?p=92169. You can get an idea of parts pricing for your rebuild here:http://www.flatlanderracing.com/ look under "engine kits". I think the concensus here is that you would be better off overseeing your own rebuild than buying a crate engine from Pep Boys or wherever. Do a search on this site for "engine rebuild" and you'll find lots of other information posted already. Good Luck! -Moose |
| Author: | eugenefelisco [ Sat May 26, 2007 12:32 pm ] |
Thank you very much guys. So the OEM rebuild kit will be chrysler 225 3.7 (60-80) slant six mechanical from Flatlander Racing website. Its about $375 plus shippnig and tax is not very bad at all. Any trick of the trade I need to know before I start the build, like any secrets or special techniques on this engine. Maybe someone can share some info here. Thank you very much, any help will be appreciated. Eugene |
| Author: | rock [ Sat May 26, 2007 1:56 pm ] |
| Post subject: | To emphasize, here ar some things you really will want IMHO |
Hello, You will find out quick matt cramer knows of what he speaks! Read those threads, but IMHO, here a few things you REALLY oughta get: The forum special on the Erson cams is still on...get one with the lifters and springs. As you learn more you will kick yourself if you don't put one in, and the price can't be beat. Get the Australian gaskets. Don't waste time on any other approach. Each place those gaskets go is a lot of work. Do it once. Get a set of Dutra duals, or get a front one and make your rear on. Get some form of ingnition upgrade, Pertronix, Mopar, etc. And right now the adjustable Rollmaster roller timing chain set can be had so cheaply, you are going to be in there too, just do it with the cam. The other stuff is almost endless so read and make your informed decision. For instance, I like a 4bbl manifold, other like 2bbl, just read the threads. It is a lot of fun and a forgiving engine! rock '64d100 |
| Author: | Ron Parker [ Mon May 28, 2007 7:17 pm ] |
Wo Wo lets slow down a bit and see what you are building your engine and car for what purpose. Street car , street/strip car ie crusein car. Or a all out drag car or a road race car . A lot of options and opions on what will work. But the best people are here for a Slant. Thanks Ron Parker Jaggers Fabrication Slanted Attitude Dart |
| Author: | runvs_826 [ Mon May 28, 2007 8:06 pm ] |
| Post subject: | engine rebuild |
Just my two cent's on re/building a slanter. I've built a couple high dollar v8's with my uncle, but this was a diffrent animal. It all depends on what you want to do for reliablilty vs. all-out performance. 1. Read thoroughly all the articles that doug and others have posted. 2. Gaskets and seal can come back to haunt you time and time again. Seal just about everything with some sort of sealant as a backup. 3. Upgrade to a better cam if at all possible, it was the best bang for the buck for me. (.44 lift/ 270 duration) 4.Upgrade your intake and exhaust the first time, it's just annoying to keep switching them out, I've gone from 1 to 2 barrell, and now a custom hyperpak with TBi. Good luck! The rest is all up to you and your wallet! |
