It is currently Mon Nov 23, 2026 10:45 pm
PostPosted: Tue May 29, 2007 1:05 pm
After swapping out slants in my 79 Aspen over the weekend I noticed my headpipe only measured 1 3/4" OD. I thought the Super 6's like my 79 had a bigger head pipe than their 1 barrel counter parts? The 80 Aspen 1 barrel donor car looked like it was a 2" OD pipe. Would it be beneficial at all (mileage or power wise) to have some new larger exhaust installed at a custom exhaust shop? Or is 1 3/4" more than adequate? If it would be better what size would you guys recommend?
Image Image
PostPosted: Tue May 29, 2007 1:42 pm
A 2 - 2 1/4 inch OD exhaust system does offer additional improvement.
If you do a custom system, I would get 2 1/4", just because it avoids any mis-match issues where the pipe meets the manifold.
If you are on a budget and the rest of your exhaust system is in good condition, swapping in a 2 1/4 for the first 6 feet of pipe, right off the manifold helps.
