| Axle Bearing Question https://slantsix.org/forum/viewtopic.php?t=23342 |
| Author: | sethmcneil [ Fri May 25, 2007 1:37 pm ] |
| Post subject: | Axle Bearing Question |
I am installing new bearings in an 8 1/4 today... It looks to me that they(the bearings) are lubed by the gear oil that fills the entire housing, is that accurate? If that is true, is it a necessity to pack the bearings with grease? or will the oil act as a salivant and wash the grease away anyway? |
| Author: | emsvitil [ Fri May 25, 2007 6:40 pm ] |
I don't know if the rear end oil makes it to the bearings or not....... But if it does, I'd pack them in a light grease so they're lubed until the rear-end oil gets to the bearings.............. (I'd probably just use white lithium) |
| Author: | icaneat50eggs [ Sat May 26, 2007 10:12 am ] |
Yes the diff fluid lubes the axle bearings. |
| Author: | sethmcneil [ Sat May 26, 2007 11:54 am ] |
| Post subject: | Re: Axle Bearing Question |
Quote: salivant
I meant solvent...
