It is currently Mon Nov 23, 2026 6:56 am
PostPosted: Sun May 27, 2007 7:30 am
Does anyone have the deck height measurement of a 225 block and the compression height of a stock piston? Thanks
PostPosted: Sun May 27, 2007 8:42 am
I know that the deck height is in one of Doug's articles on the 'Articles' page. :shock:
PostPosted: Sun May 27, 2007 8:49 am
I measured mine once and got .187 +- .003 if I recall correctly. I understand that they can vary quite a lot due to sloppy manufacturing tolerances.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun May 27, 2007 4:02 pm
Unless I missed it I did look in the articles first. Dak, the measurement I'm looking for is from the crank centerline to the deck.
PostPosted: Sun May 27, 2007 5:17 pm
I have two uncut blocks that both measured 10.75 inches from crank centerline to top of deck. Piston compression height is listed as 1.74 inches in my FSM. Hope this helps.
If a MedAlert bracelet is the only bling you wear......You might be getting old.
PostPosted: Mon May 28, 2007 7:11 am
The official (at least early/mid 60s) deck height was 0.141" and 10.68" from crank to deck. I have never seen a motor like this. Almost all of mine (1963 - 1975 motors) have been around 0.180" stock deck ht. This gives an actual comp ratio (w/55-60 cc head) of around 7.5 - 8:1 stock.
Users browsing this forum: Google [Bot] and 8 guests
