| Retorque intake/exhaust manifold? https://slantsix.org/forum/viewtopic.php?t=23383 |
| Author: | 79AspenSuperSix [ Tue May 29, 2007 9:43 am ] |
| Post subject: | Retorque intake/exhaust manifold? |
I just changed out six's in my 79 Aspen and reused my Super Six intake/exhaust manifold as the motor I transplanted was a '80 1 barrel. I used a FelPro gasket. Worked great, no more exhaust leaks, great vacuum. I torqued them from the inside out, back and forth side to side. Torqued them to 10 foot pounds. Do I have to retorque with this style gasket or am I good? |
| Author: | Jopapa [ Tue May 29, 2007 10:59 am ] |
I'd say it wouldn't hurt to verify that the nuts are still at 10 ft-lbs. Just check 'em in the same method/order you'd torque them in case some have loosened. |
| Author: | Eric W [ Tue May 29, 2007 11:29 am ] |
You can go up to 12ft-lbs on the manifolds to head bolts. |
