It is currently Wed May 13, 2026 8:16 pm
PostPosted: Tue Jun 05, 2007 6:15 pm
I have a 1974 D200 with 225 and 3psd..the motor is a later style 2brl motor without the spark plug tubes..am looking to put in a 904 automatic..have located a nice tranny but need the flex plate to hold it all together..i thought i read that the early slant flex plate wont work with this crank??..will a small block V8 one work?? if not anbody out there got what i need??
also the drive shaft i am pretty sure i will need to put in a new drive shaft to work with this set up...a drive shaft from a small block truck with a A904 and once piece shaft should work??
Thanks
Jeff
shffrjeff@aol.com
sorry for all the questions i have been out of the mopar game for a LONG time
PostPosted: Tue Jun 05, 2007 7:06 pm
The break for the flexplate is 67 and down for the small flange and 68 and up for the big flange.
67 and earlier trans needs an adapter ring for the converter to work in the late crank too.
If you need a later flexplate I have about 100 of them at my shop.
A small block plate will fit, but you have to elongate 1 bolt hole.
The V-8 shaft will work as long as it is for a 904.
PostPosted: Tue Jun 05, 2007 7:35 pm
thanks man.....i might have a V8 flex plate floating around some where...so far this sounds like it will be a EZ weekend swap..drive shaft might be the only part i might have trouble locating...and if i cant locate the flex plate i will probably be sending you a message =)
Thanks
Jeff
PostPosted: Wed Jun 06, 2007 4:37 pm
Hey Jeff,
I have been working on this or a similar problem and if the engine is prior to a '68, the crank end will not fit with the pilot piece of the tranny. Consequently, the flexplate for a 904 for a '68 or younger is too large for the crank of a '67 or lower. Not only is the pilot smaller for the '67 or below, but the spline is 27 or 28 vs 18 for the '68 or younger.
I have found a manufacturer that will take my '72 torque converter and fit it with the 1.55" pilot so it will fit the '66 225 cui engine. I don't know how much it will cost, but hope it will not be too bad, since the torque converter is pretty inexpensive.
I hope this does not sound like I don't know what I am talking about, since I don't.
Roger
I have a '72 Duster with a 225 in it and an auto tranny. It has 60k on it , but has been in the weather for a lot of years.
Users browsing this forum: Google [Bot] and 8 guests
