It is currently Sun Nov 29, 2026 6:25 pm
 Post subject: 833OD vs 833 shifting
PostPosted: Wed Jul 25, 2007 3:51 pm
I just read the informative 833 article and have a question about the OD version. It says the shifter is tricked into thinking it is a regular shift between 3rd and 4th due to the OD trans. What exactly do I need to do to get the shift correctly that is different from the regular 833?? I seem to be missing something--maybe a few brain cells!!!
 Post subject: The front paddle....
PostPosted: Wed Jul 25, 2007 4:38 pm
The front shift paddle is positioned on the 'toggle' differently than the standard A-833...the paddle is pointed up/reversed so the 3-4 shift in the A-833 will become a 4-3 position shift (which is actually a 3-OD shift) since the gearing in the box is sized differently...
PostPosted: Wed Jul 25, 2007 5:49 pm
Because of this differance the 3-4 shift arm is longer in the 833od and has a bend than the standard 833 shifter arm does not. The other linkage arms
are the same as the standard 833 set.
Here is how I did it, not the cleanest application, but it works.
http://imageevent.com/jeffc/scampworks? ... =4&s=0&z=2
The front "tab" or flag would be "up" on a standard 833 like
the 1-2 shifter tab, not down like in the photo.
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Belveder A318 727 4d
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4spOD
Old iron or no iron
Users browsing this forum: geotunes and 3 guests
