Cam Timing
https://slantsix.org/forum/viewtopic.php?t=23414
Page 1 of 1
Author:  kmccabe56 [ Thu May 31, 2007 9:49 am ]
Post subject:  Cam Timing
I'm putting a Rollmaster timing chain & gear set into an otherwise completely stock '79 Super Six.
What should the cam be dialed in to, to maximize bottom end torque & fuel economy.
Author:  Doc [ Thu May 31, 2007 10:57 am ]
Target 2 to 3 degrees advanced when using a new chain and gear set.
Author:  kmccabe56 [ Fri Jun 01, 2007 5:26 am ]
Thanks very much.
Author:  rock [ Sat Jun 02, 2007 4:44 am ]
Post subject:  Doc, how about when mfgr says 4 degrees advanced?
Doc,
My rollmaster set came with instructions specifying 4 degrees advance for the Erson cam from the forum deal. Plus with my current project of putting in a 727 in place of the 833OD in my d100 (just for the expereicne) , would you recommend your 2 - 3 degrees, or stay with the 4 or even more given the automatic and a 2000 stall convertor on a 3.91?
rock
'64d100
Author:  Doc [ Mon Jun 04, 2007 10:26 am ]
Anywhere from 2 to 4 degrees advance will be fine.
I think Erson grinds the cam with 2 degrees of advance.
