It is currently Sat Jun 06, 2026 5:38 pm
 Post subject: wheels... pics?
PostPosted: Mon Nov 26, 2007 3:58 pm
well im gonna have to give up my small bolt modern mag rims... goin to discs, are these worth much?
anyways, im seeing who has pics of there abody with some ok wheels on them, tryin to get ideas, maybe prices
PostPosted: Mon Nov 26, 2007 6:47 pm
fyi,,, Stainless Steel Brakes Corp. their rotors have both patterns and come with studs installed, just knock out the ones that are not needed.
This of course will not do any good if you have your disc set up already.
PostPosted: Wed Nov 28, 2007 12:35 pm
woa, hold the phone....
these rotors have a captured hub right. so maybe a lil spendy discs, i havnt installed them, but this is awesome to know... if tru.... ill look into it.
u might have saved my day!!!!!!!!!!!
PostPosted: Thu Dec 06, 2007 5:49 pm
Here's a picture of my SSBC disc brake conversion. I beleive the 14" small bolt pattern rallye wheels will fit. Since I was upgrading from 13" wheels, I chose to go with 15" x 7" small bolt pattern wheels from Vintique.
Don
PostPosted: Fri Dec 07, 2007 10:07 am
my swinger has the ones in my signature. I like them both for different reasons- the rallies are period correct while the a/r torquethrust 2's have that classic 5 spoke mag look that will grey out nicely since they are polished, not chromed. Gotta admit I got a little carried away with the 17's but I still think they look nice. I had to go with the a/r's because of a disc swap, same as you.
good luck
radar
madam im adam
PostPosted: Sun Dec 09, 2007 11:16 pm
i just callec SSBC and they said they dont carry anything for my valiant, call year one.... uh should i be lookin this up for somethin else... sigh
PostPosted: Sun Dec 09, 2007 11:23 pm
What year is your Valiant, what brakes does it have now and what brakes do you want? You can put this info in your profile or signature for those like me that actually look.
My best guess is you have 9" drums and SSBC only has kits for the 10" drum spindle. I think Scarebird is your best bet for a disc conversion in this case.
PostPosted: Sun Dec 09, 2007 11:32 pm
my valiant is a 72. i have a 73 dart parts car wit disc setup, i just want to use my smaller bolt pattern rims if possible, but can find where to get the smaller pattern rims
 Post subject: Brakes
PostPosted: Mon Dec 10, 2007 5:00 am
Humm, Just looked in the Year One Catalog ..... PN#DK63HP or DK63 for standard calipers. Must use 10 " drum brake spindles.
SSBC PN # A153-2BK is the same set up .This is what I got for my Dart
PostPosted: Mon Dec 10, 2007 10:16 am
Sorry, but you gotta give to get. You either give up cash for the Scarebird setup and save your small bolt pattern wheels or use the better brakes off the '73 Dart and it's wheels.
PostPosted: Thu Dec 13, 2007 4:52 pm
or piece together a kelsey-hays system-
small bolt pattern - four piston calipers
