It is currently Tue Nov 24, 2026 9:01 pm
 Post subject: Cam Timing
PostPosted: Thu May 31, 2007 9:49 am
I'm putting a Rollmaster timing chain & gear set into an otherwise completely stock '79 Super Six.
What should the cam be dialed in to, to maximize bottom end torque & fuel economy.
PostPosted: Thu May 31, 2007 10:57 am
Target 2 to 3 degrees advanced when using a new chain and gear set.
PostPosted: Fri Jun 01, 2007 5:26 am
Thanks very much.
PostPosted: Sat Jun 02, 2007 4:44 am
Doc,
My rollmaster set came with instructions specifying 4 degrees advance for the Erson cam from the forum deal. Plus with my current project of putting in a 727 in place of the 833OD in my d100 (just for the expereicne) , would you recommend your 2 - 3 degrees, or stay with the 4 or even more given the automatic and a 2000 stall convertor on a 3.91?
rock
'64d100
PostPosted: Mon Jun 04, 2007 10:26 am
Anywhere from 2 to 4 degrees advance will be fine.
I think Erson grinds the cam with 2 degrees of advance.
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
