It is currently Wed Nov 25, 2026 7:39 am
 Post subject: Distributor Governor
PostPosted: Wed Jun 06, 2007 12:19 pm
Guys that have welded up the slots in the distributor...
What method of welding did you use? A guy I talked to about welding it for me said that he would have to weld it up with brass or I would never be able to file it down to get it to the length I wanted.
Anyone have some advice?
 Post subject: Mig it...
PostPosted: Wed Jun 06, 2007 1:08 pm
I have a brass shapped bar that is the same size as the 9R slot, I just insert it into the slot and use a buddy's flux core mig welder, tack it to fill the slot, then lightly grind it flat, file/die grind to desired length, remeasure with caliper to make sure it's just right (takes about 15 minutes if you're a perfectionist with a 15-17L/R governor...)
PostPosted: Wed Jun 06, 2007 3:06 pm
I welded with steel. Took some time to file, but not a great amount of time.
Mitch
PostPosted: Wed Jun 06, 2007 7:37 pm
Using the formula I found that I need to shorten the slot .100 of an inch. I guess I will have the guy weld it up tomorrow if he has the chance. Thanks for the help guys.
Users browsing this forum: Google [Bot], Rick Covalt and 4 guests
