It is currently Sat Jun 20, 2026 3:41 pm
 Post subject: Exhaust flange gasket
PostPosted: Sun Sep 29, 2013 12:54 pm
Car Model: 1962 Dodge Lancer
Just installed a fel-pro flange gasket to try and cure a major leak, it helped a bit, but still a slight leak. Is there any problem solver type gaskets, or something a little thicker out there for us to use? I did a search, but am only coming up with the intake/exhaust gasket. Any help is much appreciated.
PostPosted: Sun Sep 29, 2013 1:09 pm
Remflex. $16 for two, but well worth it.
http://catalog.remflex.com/MOPAR_Header ... p/6005.htm
PostPosted: Sun Sep 29, 2013 1:21 pm
You are the man Reed, thank you :D
PostPosted: Sun Sep 29, 2013 1:43 pm
Wait, I linked you to the wrong one. You want the 2 1/4 gasket, not the 2 1/2 gasket.
http://catalog.remflex.com/MOPAR_Header ... p/6006.htm
Same price, though.
PostPosted: Sun Sep 29, 2013 1:52 pm
Ah thank you!
 Post subject: Remflex
PostPosted: Sun Sep 29, 2013 7:10 pm
Simply the best, I agree Reed. No leaks, I use them on exhaust/intake manifold and for exhaust down pipes.
PostPosted: Sun Sep 29, 2013 11:23 pm
I use the Remflex PN 6006 on all my Chrysler's, and Slant Six engines.
