| Distributor Governor https://slantsix.org/forum/viewtopic.php?t=23499 |
| Author: | 73dart_swinger [ Wed Jun 06, 2007 12:19 pm ] |
| Post subject: | Distributor Governor |
Guys that have welded up the slots in the distributor... What method of welding did you use? A guy I talked to about welding it for me said that he would have to weld it up with brass or I would never be able to file it down to get it to the length I wanted. Anyone have some advice? |
| Author: | DusterIdiot [ Wed Jun 06, 2007 1:08 pm ] |
| Post subject: | Mig it... |
I have a brass shapped bar that is the same size as the 9R slot, I just insert it into the slot and use a buddy's flux core mig welder, tack it to fill the slot, then lightly grind it flat, file/die grind to desired length, remeasure with caliper to make sure it's just right (takes about 15 minutes if you're a perfectionist with a 15-17L/R governor...) -D.Idiot |
| Author: | MitchB [ Wed Jun 06, 2007 3:06 pm ] |
I welded with steel. Took some time to file, but not a great amount of time. Mitch |
| Author: | 73dart_swinger [ Wed Jun 06, 2007 7:37 pm ] |
Using the formula I found that I need to shorten the slot .100 of an inch. I guess I will have the guy weld it up tomorrow if he has the chance. Thanks for the help guys. |
