| Kelsy Hayes Disk vs Drum set up questions https://slantsix.org/forum/viewtopic.php?t=23505 |
| Author: | Shaker223 [ Wed Jun 06, 2007 7:32 pm ] |
| Post subject: | Kelsy Hayes Disk vs Drum set up questions |
I have a complete 70 KH set up... My question is: are the upper and lower ball joints the same as the drum brakes as well as the upper control arm.....Also, who sells a rebuild kit for the calipers? Thx |
| Author: | SlantSixDan [ Wed Jun 06, 2007 9:59 pm ] |
Are you starting with 9" or 10" drum brakes? Caliper rebuild kits are still available through normal brake parts suppliers. |
| Author: | Shaker223 [ Thu Jun 07, 2007 5:21 am ] |
I have currently have 9" drums. |
| Author: | 65valiant310 [ Sat Jun 09, 2007 8:19 pm ] |
upper are the same...lower bolts are larger thats it |
| Author: | green convertible [ Sun Jun 10, 2007 12:15 am ] |
I did this conversion a few years back I drilled the lower ball joint mounting holes to fit the spindle mounting bolts which were bigger but placed in teh same spot. I believe it went from 1/2 to 9/16. I hope this helps. I recomend rebuilding the calipers because they will surely have buildup in in the pistons. Hope this is helpful Richard |
| Author: | Pierre [ Mon Jun 11, 2007 2:50 pm ] |
I opted to get new balljoints instead of drilling the bolt holes out. That area is low on material enough as it is and I didn't have a drill press. I suppose you could do it with a hand drill but with a bit that big..... |
| Author: | Shaker223 [ Tue Jun 12, 2007 4:15 am ] |
I bought the ball joints. The disks ball jounts were actually cheaper than the ones for drum. I have another thread going about the proportioning valve but no answers yet. Is it the same for disk and drum brakes? |
| Author: | green convertible [ Tue Jun 19, 2007 10:47 am ] |
i would imagine so. the prop valve I got from summet. its an inline deveice between the master cylinder rearward line and the rear brakes. I would have bought the new bj's but I didnt have any cash at the time and as usual did the job on a shoe string and te bjs were good. I beat the po*p out of it and they didnt fall off yet, but yes, not a lot of meat there. Watch out for sticky pisotns on old KH's and thanks again Dan for the tip on the booster rebuild in portland or. |
| Author: | HyperValiant [ Tue Jun 19, 2007 3:19 pm ] |
I have got the K-H brakes on both of my early A-bodys and used the adjustable prop valve from Summit on both and works really wellasmatter o fact,my Dart stops as well or better than most of the cars I have owned and is very predictable.The biggest drawback to the K-H setup is the cost of the components. HyperValiant |
| Author: | dakight [ Tue Jun 19, 2007 3:20 pm ] |
Drum brakes do no use a proportioning valve, only a simple distribution block. Proportioning valves are used only with disk brakes. |
| Author: | Shaker223 [ Tue Jun 19, 2007 3:59 pm ] |
thanks...just checking because I'm doing the drum to disk conversion. I'm all set now |
| Author: | 65valiant310 [ Tue Jun 19, 2007 9:51 pm ] |
Hey can you post a link for the proportion valve you got from summit? |
| Author: | Dan-o [ Wed Jun 20, 2007 8:08 am ] |
Does anyone have a link to this company/kits? |
