| Low RPM Shaking, like out of balance? https://slantsix.org/forum/viewtopic.php?t=23554 |
| Author: | knuckledown [ Sun Jun 10, 2007 2:08 pm ] |
| Post subject: | Low RPM Shaking, like out of balance? |
Yesterday I replaced the valve cover gasket on my slant and now it seems as if my engine has an "out of balance" shake to it at very low RPM's. Now, I doubt that something is out of balance, I think I crossed one of the vacuum lines up with a different one. Something isn't right, tho. Help! |
| Author: | SlantSixDan [ Sun Jun 10, 2007 2:19 pm ] |
Well, your '71 does have at least two hoses running to the crankcase breather (at the back of the valve cover), one large-diameter line that runs from the PCV valve to the base of the carb, and another large-diameter line that runs from the body of the fuel pump to the top of the carb.... |
| Author: | Greg Ondayko [ Sun Jun 10, 2007 3:54 pm ] |
Did you Take off any of the plug Wires in the process?? I have crossed wires and It gave me the effect you describe. Greg |
| Author: | Sam Powell [ Sun Jun 10, 2007 4:25 pm ] |
It sounds like a plug wire is just off at one end or the other. If they are crossed you will very often get a back fire, either through the exhaust or carb. . If a spark plug wire is disconnected, then you get a foomp, foomp foomp sound in the exhaust as well. You could have a plug wire that is grounding out, and firing to ground before the plug can spark. Sam |
| Author: | knuckledown [ Sun Jun 10, 2007 5:15 pm ] |
You guys are awesome!! I'll check all of those things out. This is what I did yesterday: Drained oil and changed filter. I may have bumped the distributor when changing the oil? I then pulled the valve cover to change the gasket. What a pain!! The cork material was glued on, as well as covered in RTV sealant. I used a little parabond and a new rubber gasket. I think I put all the hoses back in the right order. Everything looks good. But I did notice that when I start my car, it idles higher and I have to kickdown the throttle to get it to run at a normal operating rpm. I'm hoping I can get some help at work tomorrow. We have a couple of former Chrysler tech's on our staff. Thank you for the help, I will certainly check those things out! |
| Author: | Doc [ Mon Jun 11, 2007 8:26 am ] |
Did you adjust the valve lash while the valve cover was off? (you should have at least checked it once the cove was off) DD |
