| manifold adapter? https://slantsix.org/forum/viewtopic.php?t=23602 |
Page 1 of 2 |
| Author: | fede-valiant [ Fri Jun 15, 2007 10:32 am ] |
| Post subject: | manifold adapter? |
Hi guys! Im about to replace my old one barrel holley for a 40/40 dual barrel... I need to know if its possible to adapt my manifold (one hole) to palce the new carb... is it possible, I mean without changing the original manifold? Thanks! |
| Author: | oldgoat83 [ Fri Jun 15, 2007 12:13 pm ] |
If you search on here for such a thing, you will find that it is possible, but not recommended. |
| Author: | SlantSixDan [ Fri Jun 15, 2007 1:04 pm ] |
It is possible, but it is a bad idea. Much better to start with a manifold intended for a 2bbl carburetor. |
| Author: | icaneat50eggs [ Fri Jun 15, 2007 1:33 pm ] |
Like trying to breathe through a straw. |
| Author: | fede-valiant [ Fri Jun 15, 2007 2:44 pm ] |
Why is it not recommended? Does it lose power?? has someone done it with bad experience?? Thanks. www.dodge-tech.com.ar/forum |
| Author: | icaneat50eggs [ Fri Jun 15, 2007 3:09 pm ] |
The one barrel opening is too restrictive |
| Author: | Jopapa [ Fri Jun 15, 2007 3:25 pm ] |
Quote: The one barrel opening is too restrictive
Is it the bore of the single barrel opening on the manifold, or are the manifold runners themselves smaller than those of a Super Six manifold? If it's only the opening for the carb, them I would think that could be machined out, with new holes drilled for appropriately placed studs for a 40/40. But I'm only speaking in the sense of thinking that it could physically be done. I would expect starting with a Super Six intake manifold would still be far more feasable.
| Author: | emsvitil [ Fri Jun 15, 2007 3:31 pm ] |
The bore in the manifold is the same size as the 1bbl carb. With an adaptor the 2 bbls neck down to the 1bbl size, thus no gain. Modifying the 1bbl manifold has been done (bet SSDan knows the link) for 2bbl carbs |
| Author: | radarsonwheels [ Fri Jun 15, 2007 3:51 pm ] |
| Post subject: | huh? |
If the runners are the same size, why not just hog out the manifold to the same size as the carb gasket? It would be easy to use the adapter as a guide, and don't people use carb spacers as a performance upgrade anyway? I figured that people here would be into doing it themselves? Or maybe the 2 barrel manifold isn't that hard to find? Kevin |
| Author: | mrhite65 [ Fri Jun 15, 2007 4:18 pm ] |
Is this what you're trying to do? ![]()
| Author: | SlantSixDan [ Fri Jun 15, 2007 4:18 pm ] |
The 2bbl intakes aren't hard to find in North America. Not sure what the situation is in Argentina. Here's an article (pdf) on how to grind & modify a 1bbl intake to accommodate a 2bbl carb, with parallel orientation (factory 2bbls were perpendicular). |
| Author: | dakight [ Fri Jun 15, 2007 4:23 pm ] |
It can be done but there isn't a lot of real estate to work with and a 40/40 is a sizable pair of bores. It would be tricky at best. Even the "Super Six" manifold will require an adapter. I would think it would be more feasable with a 4 bbl manifold such as a Clifford or Offy. You would then be able to turn the carb 90* for improved fuel/air distribution. It seems to me anyway, but I've never done it - maybe someone here has. |
| Author: | 61 V200 [ Sat Jun 16, 2007 8:51 am ] |
Here's my modified 1 bbl ![]()
| Author: | Rug_Trucker [ Sun Jun 17, 2007 8:35 am ] |
I've seen stock intakes modified to 4bbls! BTW what is a 40/40? 40mm? |
| Author: | dakight [ Sun Jun 17, 2007 6:59 pm ] |
That's what I took it to be; 2 barrels, 40 mm each. Tha'ts a big carb. |
| Page 1 of 2 | All times are UTC-07:00 |
