It is currently Thu Nov 19, 2026 9:02 pm
PostPosted: Tue Jul 17, 2007 8:14 am
I was going to set my valve lash until I found that ALL of the rocker arms were plugged and one pushrod was bent. I have the rockers soaking, but I'd like to do a compression check while I'm waiting for the gunk in the oil passages to loosen up. Can I do a compression check with the rockers out? I'm thinking without the valves opening it won't be worthwhile, but thought I'd ask anyway.
Thanks,
John
66 Barracuda 225 auto
PostPosted: Tue Jul 17, 2007 9:19 am
Yes, the valves need to open and close to get compression reedings.
BTW,
On your clogged rocker arms, you should find yourself a good used (unclogged) rocker arm assembly to use. It is unlikely you will be successful in getting all 12 arms unclogged. (and you can spend hours trying)
PostPosted: Tue Jul 17, 2007 11:04 am
I'll keep my eyes open for a good set. I'm not in a hurry, so its worth trying to save them. I need to run up on a used crock pot to turn into a hot tank :wink: I appreciate the help.
John
PostPosted: Tue Jul 17, 2007 12:33 pm
I have some extra good used RA assemblies, drop me a PM if you need one.
PostPosted: Tue Jul 17, 2007 4:52 pm
somone had an NOS set on Ebay last week, the price didnt seem too bad. If youre not in a hurry it would be worth watching there.
PostPosted: Tue Jul 17, 2007 5:46 pm
Those show up on Ebay with some regularity. I've been tempted myself but I think I have everything I need.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Tue Jul 17, 2007 8:39 pm
Thrift shops, Goodwill stores, etc. usually have plenty of used crock pots for sale for a couple of dollars or so.
1964 Dart 225 1966 Valiant 225
1966 Dart 273 1966 Barracuda 273
1969 Dart 225
'64-170 engine '66-170 engine
(two) 198 crank/rod sets in custom-fitted wooden boxes
wooden motor scooter with hybrid-electric drive
Users browsing this forum: Amazon [Bot], Bing [Bot], DuckDuckGo [Bot] and 4 guests
