| Tuning Help https://slantsix.org/forum/viewtopic.php?t=23661 |
| Author: | runvs_826 [ Tue Jun 19, 2007 5:26 pm ] |
| Post subject: | Tuning Help |
My pa and I having been tuning my slant six for a little why now and ran into a problem. I've been homing on about 200 degrees, and am not running a thermo cause it used to really screw up my temp and run it over. Next, we have a slight tick at exactly 2100rpm on the tach. I milled .1 off the head and so the cr is whatever that relates too, I run premium to make up for that. We installed an HEI(8 pin) igintion system. So any fixes to the overheating and the tick are my problems. Thanks, ahead of time. |
| Author: | SlantSixDan [ Tue Jun 19, 2007 5:40 pm ] |
| Post subject: | Re: Tuning Help |
Quote: My pa and I having been tuning my slant six for a little why now and ran into a problem. I've been homing on about 200 degrees, and am not running a thermo cause it used to really screw up my temp and run it over.
You need to run a thermostat, preferably a 180. If your engine is overheating, then it is because something's wrong. Crudded-up block, crudded-up radiator, radiator tube/fin separation, improper fan or fan installed backwards, lower hose collapsing...does this overheating happen at low vehicle speeds or high vehicle speeds, or sitting idling in the driveway?Quote: Next, we have a slight tick at exactly 2100rpm on the tach.
What kind of "tick"?Quote: We installed an HEI(8 pin) igintion system.
I know 4-pin, 5-pin, and 7-pin HEI systems. What did you put in?
| Author: | runvs_826 [ Tue Jun 19, 2007 7:04 pm ] |
it's a 7pin with a ground I guess? The tick is just that a tick at 2100 rpm where the tach ticks back and forth at 2100, kinda like a miss is how I would describe it. The overheating I have no idea, the radiator is brand new. The fan blade is a possibilty along with the head being full of rust. however, I did have the head hot tanked and media blasted during build up. It wants to sit about 190 degrees without a thermo and worked it's way up during tuning to 200, is that normal for no thermo, what is my max temp than? Thanks |
| Author: | dakight [ Tue Jun 19, 2007 7:17 pm ] |
190, or even 200 is not at all a problem. With a pressurized cooling system you can go to 225 or 230 and have no problem. It's normal on a warm day, for the temp to go up a bit while idling but what you're describing is far from overheating. |
| Author: | Sam Powell [ Tue Jun 19, 2007 7:33 pm ] |
I think your old thermostat was defective. It should behave for you with a 180 in it. Sam |
| Author: | skraecken [ Tue Jun 19, 2007 10:35 pm ] |
Quote: fan installed backwards
