It is currently Wed Nov 25, 2026 5:10 am
PostPosted: Wed Jun 06, 2007 7:32 pm
I have a complete 70 KH set up... My question is: are the upper and lower ball joints the same as the drum brakes as well as the upper control arm.....Also, who sells a rebuild kit for the calipers? Thx
PostPosted: Wed Jun 06, 2007 9:59 pm
Are you starting with 9" or 10" drum brakes? Caliper rebuild kits are still available through normal brake parts suppliers.
PostPosted: Thu Jun 07, 2007 5:21 am
I have currently have 9" drums.
PostPosted: Sat Jun 09, 2007 8:19 pm
upper are the same...lower bolts are larger thats it
PostPosted: Sun Jun 10, 2007 12:15 am
I did this conversion a few years back I drilled the lower ball joint mounting holes to fit the spindle mounting bolts which were bigger but placed in teh same spot. I believe it went from 1/2 to 9/16.
I hope this helps. I recomend rebuilding the calipers because they will surely have buildup in in the pistons.
Hope this is helpful
Richard
63 valient 4 speed over drive, holly 390, dutra duals, power steering, ac, hydraulic roof, KH 4 piston disks, kyb gas adjust all round, sway bars front and rear, 8 3/4 rear axcel and the ugliest green you ever saw
PostPosted: Mon Jun 11, 2007 2:50 pm
I opted to get new balljoints instead of drilling the bolt holes out. That area is low on material enough as it is and I didn't have a drill press. I suppose you could do it with a hand drill but with a bit that big.....
PostPosted: Tue Jun 12, 2007 4:15 am
I bought the ball joints. The disks ball jounts were actually cheaper than the ones for drum.
I have another thread going about the proportioning valve but no answers yet. Is it the same for disk and drum brakes?
PostPosted: Tue Jun 19, 2007 10:47 am
i would imagine so. the prop valve I got from summet. its an inline deveice between the master cylinder rearward line and the rear brakes.
I would have bought the new bj's but I didnt have any cash at the time and as usual did the job on a shoe string and te bjs were good. I beat the po*p out of it and they didnt fall off yet, but yes, not a lot of meat there. Watch out for sticky pisotns on old KH's and thanks again Dan for the tip on the booster rebuild in portland or.
PostPosted: Tue Jun 19, 2007 3:19 pm
I have got the K-H brakes on both of my early A-bodys and used the adjustable prop valve from Summit on both and works really wellasmatter o fact,my Dart stops as well or better than most of the cars I have owned and is very predictable.The biggest drawback to the K-H setup is the cost of the components.
HyperValiant
1960 Hyper-Pac Valiant(rolling test-bed)
1963 Valiant V2OO(Son's summer project,- he just turned 15 :-) )
1972 Valiant 4dr(Daughter Kelly's repair in progress)
1974 Valiant (v8) daughter Kelly's work in progress
PostPosted: Tue Jun 19, 2007 3:20 pm
Drum brakes do no use a proportioning valve, only a simple distribution block. Proportioning valves are used only with disk brakes.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Tue Jun 19, 2007 3:59 pm
thanks...just checking because I'm doing the drum to disk conversion. I'm all set now
PostPosted: Tue Jun 19, 2007 9:51 pm
Hey can you post a link for the proportion valve you got from summit?
PostPosted: Wed Jun 20, 2007 8:08 am
Car Model: Road Runner
Does anyone have a link to this company/kits?
Users browsing this forum: Amazon [Bot] and 5 guests
