| Master Cylinder https://slantsix.org/forum/viewtopic.php?t=23699 |
| Author: | 73dart_swinger [ Thu Jun 21, 2007 5:14 pm ] |
| Post subject: | Master Cylinder |
My drum brake master cylinder is leaking. I plan on upgrading to discs in the future. Will a disc brake mc work with my drums so I don't have to buy 2 new master cylinders? |
| Author: | SlantSixDan [ Thu Jun 21, 2007 5:18 pm ] |
Yup no problem. |
| Author: | 73dart_swinger [ Thu Jun 21, 2007 6:06 pm ] |
That's what I thought, just wanted to double check. |
| Author: | 72polara [ Fri Jun 22, 2007 9:27 am ] |
Hey Dan, not trying to be contrary, but are you sure? iirc, it depends on what wheel cylinders you are using... the earlier ones needed a residual pressure valve (in the MC), whereas the newer wheel cylinders and 'problem solver' wheel cylinders had an expander built into the wheel cylinder. Or am I just confused and the residual pressure is handled by the drum brake combo valve? |
| Author: | SlantSixDan [ Fri Jun 22, 2007 9:41 am ] |
RP valves went away when wheel cylinder seals were revised in '73. It is highly, highly, highly unlikely there are any old-style wheel cylinder seals are still in the current parts market. |
| Author: | 73dart_swinger [ Fri Jun 22, 2007 9:42 am ] |
My car is a 73 and I when I got it, it had a disc brake mc. It leaked but seemed to work fine. |
