Wiring Harness Swap
https://slantsix.org/forum/viewtopic.php?t=23705
Author:  dncoles [ Fri Jun 22, 2007 11:31 am ]
Post subject:  Wiring Harness Swap
Hey guys, I have a question. I have already searched to see if someone posted something similar but I didn't find anything. I noticed that my gauges didn't work and after working on it and updating the cluster board, I found out that it still didn't work plus none of the lights work. After comparing the wiring under the hood with my service manual, I saw that the previous owner cut wires and never hooked them back. Now I could go through the work of fixing the chopped up wires on the harness but they are VERY short now. So I thought I might find a donor close by that I could take the harness out and replace it. My question is, what models would match up besides the exact same model? Such as a dart, earlier/later valiant and so on. I'm not familiar which models you can swap parts with just in case I come across one so I can pull a Dr Frankenvaliant and get this car running. Thanks Dan
