| Breather Filter Part Number for '71??? https://slantsix.org/forum/viewtopic.php?t=23716 |
| Author: | knuckledown [ Sat Jun 23, 2007 5:01 pm ] |
| Post subject: | Breather Filter Part Number for '71??? |
Does anyone know the part number for the breather filter that has the nipple coming off the bottom of the filter??? No auto supplier around here can seem to find the correct one. |
| Author: | SlantSixDan [ Sat Jun 23, 2007 5:32 pm ] |
This one's been N/A for many years. It was used only on '71 (plus '70 California) slant-6s. Your best bet will be to buy an ordinary '72-up breather (NAPA filter # 2997, Wix 42997, Standard BF28) which looks like this: ![]() Then, insert a metal 5/16" Tee or Wye in the hose that runs from your carburetor bowl vent to the fuel pump's body casting (this is not the fuel supply line! Pay attention and make sure you get the right one!). Connect the hose that used to go to the breather to the Tee or Wye. |
| Author: | knuckledown [ Sat Jun 23, 2007 5:42 pm ] |
I owe you a million "thank you's" Dan! |
