parking brake trans seal
https://slantsix.org/forum/viewtopic.php?t=23760
Author:  lincparts [ Mon Jun 25, 2007 4:12 pm ]
Post subject:  parking brake trans seal
63 valiant wagon 170/pushbutton 3 spd, the seal that the parking brake cable enters in the rear of trans is leaking(gasket is split), is it readily available and if so where?
Author:  AnotherSix [ Sun Jul 01, 2007 9:29 am ]
I would try bulkparts.com They seem to have most everything and are inexpensive. I think they have a minumum purchase policy. You may just want to get an overhaul gasket and seal set, they are not that much.
Author:  SlantSixDan [ Sun Jul 01, 2007 11:27 am ]
Suggest getting your early-Torqueflite seals and parts from Pat Blais, tflitepatty@verizon.net . Pat is very knowledgeable about these transmissions and can save you a lot of "oops, not quite the right part" or "oops, have nine out of the eleven parts I need" grief.
Author:  lincparts [ Mon Jul 02, 2007 8:56 am ]
Post subject:  thanks for the leeds
thanks to Anotherslant and slant six dan for your help!!! Will contact said people.
