| Timken bearing #s? https://slantsix.org/forum/viewtopic.php?t=23858 |
| Author: | Jopapa [ Sun Jul 01, 2007 10:01 pm ] |
| Post subject: | Timken bearing #s? |
Anyone have the right bearing numbers for the front wheels (both inner and outer) on a '74 disc brake A body? I figure if I'm pulling my front brakes off to replace the lug studs, I better do the job right and install new bearings as well. |
| Author: | DionR [ Mon Jul 02, 2007 1:01 pm ] |
Check the new Mopar Action mag, Rick put slotted and drilled rotors on his Beeper and mentioned the part numbers. |
| Author: | SlantSixDan [ Mon Jul 02, 2007 1:05 pm ] |
Looks like Timken SET2 outer, SET17 inner BCA/National A2 outer, A17 inner. |
| Author: | 65 dartman [ Mon Jul 02, 2007 4:04 pm ] |
Went to my local NAPA and they had in stock inner and outer bearings and races for both my 65-72 KH's and 73-76 discs. Might try your NAPA. |
| Author: | Jopapa [ Mon Jul 02, 2007 4:20 pm ] |
Quote: Went to my local NAPA and they had in stock inner and outer bearings and races for both my 65-72 KH's and 73-76 discs. Might try your NAPA.
Yeah that's what I did. Would've rather waited to have Timken bearings delivered, but I want to get this stuff done as soon this week as I can so I can drive the Duster again. Got Federal Mogul bearings, but I'll have a set of Timkens ready to go when it comes time to replace the rotors completely.
