It is currently Wed Nov 25, 2026 10:22 am
 Post subject: Timken bearing #s?
PostPosted: Sun Jul 01, 2007 10:01 pm
Anyone have the right bearing numbers for the front wheels (both inner and outer) on a '74 disc brake A body? I figure if I'm pulling my front brakes off to replace the lug studs, I better do the job right and install new bearings as well.
PostPosted: Mon Jul 02, 2007 1:01 pm
Check the new Mopar Action mag, Rick put slotted and drilled rotors on his Beeper and mentioned the part numbers.
'15 Chrysler 200S V6
'74 Duster 360, factory 4 speed car
PostPosted: Mon Jul 02, 2007 1:05 pm
Looks like Timken SET2 outer, SET17 inner
BCA/National A2 outer, A17 inner.
PostPosted: Mon Jul 02, 2007 4:04 pm
Went to my local NAPA and they had in stock inner and outer bearings and races for both my 65-72 KH's and 73-76 discs. Might try your NAPA.
PostPosted: Mon Jul 02, 2007 4:20 pm
Yeah that's what I did. Would've rather waited to have Timken bearings delivered, but I want to get this stuff done as soon this week as I can so I can drive the Duster again. Got Federal Mogul bearings, but I'll have a set of Timkens ready to go when it comes time to replace the rotors completely.
