| Anyone up for some decoding? https://slantsix.org/forum/viewtopic.php?t=23906 |
| Author: | 73dartcustom [ Thu Jul 05, 2007 11:58 am ] |
| Post subject: | Anyone up for some decoding? |
Any help in decoding this would be greatly appreciated. M21 M25 M26 M38 V5X END V1G U 22 F16 G52 L31 KG8 L1G6 KG6 A16 284014 E24 D34 LH41 C4R 135462 |
| Author: | oldgoat83 [ Thu Jul 05, 2007 1:58 pm ] |
What's it from? |
| Author: | SlantSixDan [ Thu Jul 05, 2007 2:28 pm ] |
It's a '74 Dart sedan. E24: 225 cubic inch 1bbl 6-cylinder engine D34: Torqueflite automatic transmission, standard duty L: Dart H: High trim/price class 41: 4-door sedan C: 225 cubic inch, 105 net HP 1bbl 6-cylinder engine 4: 1974 model year R: Windsor, Ontario build plant 135462: Vehicle serial number KG8: Paint code L1G6: Interior trim (Low price class, cloth & vinyl bench, white & green) KG6: Upper door frame paint A16: Build date 10/16/73 284014: Vehicle order number V1G: Black vinyl roof U: Built to US market specifications 22: 22" radiator width F16: Unknown fleet/heavy-duty code, possibly alternator-related G52: Driver's side remote control chrome sideview mirror L31: Fender-mount turn signal indicators M21: Roof drip rail moldings M25: Wide sill moldings M26: Wheel well moldings M38: Deck lid finish panel molding V5X: Black protective bodyside moldings END: End of codes |
| Author: | GTS225 [ Thu Jul 05, 2007 3:01 pm ] |
That's not what I got, Dan! It says..."Jimmy Hoffa's UFO will land on Mount Rushmore during the second blue moon of November".......Oh, wait! I used my secret agent decoder ring..... Roger |
| Author: | DusterIdiot [ Thu Jul 05, 2007 6:07 pm ] |
| Post subject: | Need a better book...or CD |
Quote: KG8: Paint code
'Deep Sherwood Metallic' (There's a Feather Duster across town with this one, it's a nice 'dark Hunter green' look).Quote: F16: Unknown fleet/heavy-duty code, possibly alternator-related
That's an alternator code, it's for one that's under 80 amps...but not the little 46 amp wonder...Sounds like a good car... -D.Idiot |
| Author: | 73dartcustom [ Fri Jul 06, 2007 4:50 pm ] |
| Post subject: | Black vinyl roof? |
It has a green one of similar color to the paint. Non original?[/quote] |
| Author: | DusterIdiot [ Fri Jul 06, 2007 7:19 pm ] |
| Post subject: | Oops, you're right... |
Quote: V1G: Black vinyl roof
V1X is a Black full vinyl roof...V1G, is a Green full vinyl roof...Gotta get Dan a better decoder ring, the inventor of his had too much Molson's...Eh!??! -D.Idiot |
| Author: | quarter mile heartbeat [ Sat Jul 07, 2007 4:03 am ] |
So where does one find the tables to decode VIN's like this? |
| Author: | DodgeGirl [ Sat Jul 07, 2007 6:35 am ] |
http://www.stockmopar.com/mopar-fender-tag-decoder.php |
| Author: | SlantSixDan [ Sat Jul 07, 2007 9:03 am ] |
| Post subject: | Re: Oops, you're right... |
Quote: Quote: V1G: Black vinyl roof
V1X is a Black full vinyl roof...V1G, is a Green full vinyl roof...Quote: Gotta get Dan a better decoder ring, the inventor of his had too much Molson's...Eh!??!
Oh, either that or I should get my next decoder ring out of a box of cereal that's not past its "eat by" date.
| Author: | SlantSixDan [ Sat Jul 07, 2007 9:05 am ] |
That's a good one. There are many lists of fender tag codes out there, and each one seems to contain different omissions and errors, so I like to cross-check codes I'm not completely sure on, to see if I can at least come up with a consensus. Paint codes aren't provided on any of the fender tag code lists, so (when I remember, thanks DI) I grab the paint code off the fender tag, head over to www.autocolorlibrary.com , look at the paint chip chart for the year and make in question, find the fender tag paint code and retrieve the paint supplier's colour code from the relevant chip. |
| Author: | 73dartcustom [ Sat Jul 07, 2007 9:56 am ] |
Thanks for all of the info |
| Author: | Chrycoman [ Fri Jul 20, 2007 11:46 am ] |
F16 is for a 34 amp alternator KG8 - The "K" is for the year that shade was introduced, in this case the 1974 model year. It is a slightly different shade from 1973's JG8 (Dark Green Metallic). KG8 was also used in 1975-76 |
