It is currently Sat Nov 21, 2026 10:13 pm
PostPosted: Sun Jul 08, 2007 12:17 pm
I have a 68 D100 and i pulled it out of a pasture 2 years ago. i cleaned out the fuel tank and did other little maintanence things and i have driven it as a daily driver on and off again. Its starting to run a little rough so i am going to change the points and the timing chain and i was curious was the breaker gap on the points is and what the timing degrees were. thanks
PostPosted: Sun Jul 08, 2007 12:33 pm
Welcome to the forum. A running truck pulled out of a pasture is a good find! Point gap is 0.020", and basic ignition timing would do well at around 5° BTDC, but you will definitely want to pick up the factory service manual for the truck. Good sources discussed in this thread.
