New to forum, need some specs
https://slantsix.org/forum/viewtopic.php?t=23957
Author:  kro [ Sun Jul 08, 2007 12:17 pm ]
Post subject:  New to forum, need some specs
I have a 68 D100 and i pulled it out of a pasture 2 years ago. i cleaned out the fuel tank and did other little maintanence things and i have driven it as a daily driver on and off again. Its starting to run a little rough so i am going to change the points and the timing chain and i was curious was the breaker gap on the points is and what the timing degrees were. thanks
Author:  SlantSixDan [ Sun Jul 08, 2007 12:33 pm ]
Welcome to the forum. A running truck pulled out of a pasture is a good find! Point gap is 0.020", and basic ignition timing would do well at around 5° BTDC, but you will definitely want to pick up the factory service manual for the truck. Good sources discussed in this thread.
