what cfm should I use
https://slantsix.org/forum/viewtopic.php?t=23967
Author:  stolan83 [ Sun Jul 08, 2007 4:58 pm ]
Post subject:  what cfm should I use
Just got my block and stuff back for the machine shop. I went from .030 over with stock compression to 0.080 over with 10:1 by the way of custom positions. Right know I have a holy 390, so should I go bigger or play with jets. Oh I live in Vegas if that would make a difference 4000 feet elevation I think, But really hot it was 121 the other day
Author:  Dart270 [ Sun Jul 08, 2007 5:54 pm ]
That overbore should have no significant effect on your carb demands, but the compression might change things. Stick with the 390 and adjust jets, etc as necessary for best mixture/performance.
Author:  stolan83 [ Mon Jul 09, 2007 11:17 am ]
would it be a good idea to get an air to fuel gauge
Author:  slantzilla [ Mon Jul 09, 2007 12:50 pm ]
Yes, that would make things easier.
I would bet you will not need to go more than 4 sizes above stock on the jets though. :shock:
