It is currently Fri Nov 20, 2026 11:02 pm
PostPosted: Fri Jul 13, 2007 10:20 am
Hello folks,
Enjoyable reading the web and old forum threads about ARP head studs...except I never found a part number for the set for cast iron blocks. Learned a lot about aluminum,though!
I think I will try em out on a head milled .100. I like the idea of the head gasket not moving as head is moved into place (one man operation in back yard, skeeters, sweat, you know how it is). SO for that application what is the stud set number, length if special for that milled amount, and if any special nuts or washers needed, how bout those numbers too? Or point me to the URL where the info is clearly provided, please.
Slant six Dan are you trying out for the CBC radio opera yet?
Thanks
rock
'64d100
 Post subject: ARP Part Numbers
PostPosted: Fri Jul 13, 2007 11:02 am
Cast Iron Block SL6
Head Studs : 142 - 4001
Main Studs : 142-5401
Users browsing this forum: Ahrefs [Bot] and 8 guests
