| Need part # for cast iron block ARP head studs https://slantsix.org/forum/viewtopic.php?t=24033 |
| Author: | rock [ Fri Jul 13, 2007 10:20 am ] |
| Post subject: | Need part # for cast iron block ARP head studs |
Hello folks, Enjoyable reading the web and old forum threads about ARP head studs...except I never found a part number for the set for cast iron blocks. Learned a lot about aluminum,though! I think I will try em out on a head milled .100. I like the idea of the head gasket not moving as head is moved into place (one man operation in back yard, skeeters, sweat, you know how it is). SO for that application what is the stud set number, length if special for that milled amount, and if any special nuts or washers needed, how bout those numbers too? Or point me to the URL where the info is clearly provided, please. Slant six Dan are you trying out for the CBC radio opera yet? Thanks rock '64d100 |
| Author: | Doc [ Fri Jul 13, 2007 11:02 am ] |
| Post subject: | ARP Part Numbers |
Cast Iron Block SL6 Head Studs : 142 - 4001 Main Studs : 142-5401 DD |
