| 70 /6 Turbo- Chassis Dyno update https://slantsix.org/forum/viewtopic.php?t=24037 |
| Author: | Shaker223 [ Fri Jul 13, 2007 7:37 pm ] |
| Post subject: | 70 /6 Turbo- Chassis Dyno update |
Remember, stock /6 & 80k miles cept for 340 valve springs. 234.49 rear wheel HP/ 309.12 max torque / 20.02 max psi/ 11.4 AFR Link to original http://www.slantsix.org/forum/viewtopic.php?t=23348 |
| Author: | KRiTiK [ Fri Jul 13, 2007 9:50 pm ] |
Whoa ! That's a spicey meatball !!Have to get me one o' them hair dryers!! |
| Author: | CARS [ Fri Jul 13, 2007 11:26 pm ] |
Way to go Shaker!!! |
| Author: | Matt Cramer [ Sat Jul 14, 2007 5:28 am ] |
Congratulations! I can't wait to get mine running. |
| Author: | Sam Powell [ Sat Jul 14, 2007 5:44 am ] |
Thanks for the update! That's very cool. I am really glad to know things are working out. You should feel a real sense of accomplishment there. If you are going racing, share a timeslip with us. Sam |
| Author: | Shaker223 [ Sat Jul 14, 2007 7:30 am ] |
Unfortunatly, my weekends are booked for a while so I won't be able to make it to the track. I think the motor has more in it...just need to find it. (without opening it up, cam, porting etc). The air fuel was real stable. It settled between 11.2-11.4 for the whole run. Just wish I had time to do a few plug readings...I ran out of time because I had to be somewhere (the guy in front of me took almost 4 hours) Eventually I'd like to FI it....Sam, you're the lead on that!! |
| Author: | Matt Cramer [ Sat Jul 14, 2007 10:48 am ] |
Wow, that's some good carb tuning. |
| Author: | KRiTiK [ Wed Jul 18, 2007 5:21 pm ] |
| Post subject: | Re: 70 /6 Turbo- Chassis Dyno update |
[quote="Shaker223"]Remember, stock /6 & 80k miles cept for 340 valve springs. 234.49 rear wheel HP/ 309.12 max torque / 20.02 max psi/ 11.4 AFR Seen lotso mega elaborate NA Slant buildups over the years , almost none make these #s ...Looks like a buncho junk (& a little common sense ) beats a buncho money anyday!! Boost ON Brutha !! |
| Author: | Shaker223 [ Wed Jul 18, 2007 8:39 pm ] |
Thanks!!! Like you said, Just trying to make the junk run ...needs a header and a better exhaust after the turbo. |
