| What in the Wide Wide World of Slants do we have here? https://slantsix.org/forum/viewtopic.php?t=24049 |
| Author: | Joshie225 [ Sat Jul 14, 2007 5:49 pm ] |
| Post subject: | What in the Wide Wide World of Slants do we have here? |
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0145031764 Could this be used to couple a slant to some industrial application? There's no hole for a clutch release fork. |
| Author: | Mike Andreas [ Sat Jul 14, 2007 6:37 pm ] |
| Post subject: | High mounted starter |
It's got a high mounted starter and the bolt pattern doesn't look right. If it fits a slant maybe it a marine motor bell housing. Some of the marine setups ran the motor on its side. There is also the Clark Motor Home from the 60's that used a slant. Have your guys seen this? http://tinyurl.com/2oe8wa |
| Author: | Joshie225 [ Sat Jul 14, 2007 7:26 pm ] |
Which bolt pattern doesn't look right? The trans side? Looks to me like it was meant to drive a hydraulic pump. Most marine stuff was cast iron. Many marine bellhousings also had motor mount provisions. I know about the Clark Cortez and saw that thread. |
| Author: | Mike Andreas [ Sat Jul 14, 2007 8:29 pm ] |
| Post subject: | Yeah, You're probably right |
I bet it runs some kind of pump. It's not anything I ever seen before. |
| Author: | DynoDave [ Sun Jul 15, 2007 7:37 pm ] |
You know why it looks funny.....it's for a STANDRAD shift, not a standard shift. This from a guy who types with 2 fingers... |
| Author: | slantzilla [ Sun Jul 15, 2007 8:01 pm ] |
That housing was on the Bag a couple months ago. I would guess it fits a pump or generator. |
| Author: | Joshie225 [ Sun Jul 15, 2007 8:45 pm ] |
Generators usually support one end of the generator armature with the crankshaft and have a much more open end than this thing. This is true for my 1940s 1kW Wisconsin driven generator and the 750kW Cummins V12 driven gennys at work. I still think it's meant to drive a hydraulic pump. I asked the seller for casting numbers and if they had any idea what mounted to the bellhousing, but got no reply. I did just ask Saturday though. |
| Author: | Joshie225 [ Mon Jul 16, 2007 12:38 pm ] |
The seller replied: "this is for an industrial application Thanks ron" Some help huh? |
| Author: | Jeffc [ Mon Jul 16, 2007 9:26 pm ] |
I bet it is a pump bell, water pump that is.... a lot of slants were used to water fields....... I don't see any place to put a clutch arm so it ether didn't have a clutch or arm it was under the bell. |
| Author: | Ron Parker [ Thu Jul 19, 2007 6:48 pm ] |
could be a pump, a welder, or a aircraft tow, or a combine. or generator, I have even seen one used as a jet engine apu. Boat, Ferris Wheel ,Tilt a whirl, silo blower, Who knows. Thanks Ron Parker I Think Bagel Used One For A Sugage Grinder At One Time. |
