It is currently Wed May 13, 2026 12:46 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
 Post subject: pulleys
PostPosted: Sat Jul 14, 2001 10:59 am
Anybody know where to get a aluminum 1 grove v-belt pulley for alternator and water pump...... also will a V8 alternator pulley work on a /6 alternator how about water pump pulley
Thanks
mopar.mopar@gte.net
 Post subject: Re: pulleys
PostPosted: Sun Jul 15, 2001 8:35 am
: Anybody know where to get a aluminum 1 grove
: v-belt pulley for alternator and water
: pump...... also will a V8 alternator pulley
: work on a /6 alternator how about water pump
: pulley
: Thanks
The only difference in the alternator pulleys should be one groove or two. Any hot rod shop should be able to get one. Not sure about the water pump though. Dennis
aschumers@aol.com
PostPosted: Sun Jul 15, 2001 8:37 am
: The only difference in the alternator pulleys
: should be one groove or two. Any hot rod
: shop should be able to get one. Not sure
: about the water pump though. Dennis
Hi Dennis
You are right. Shogun Indst.makes one
Will
slantsix@netzero.net
 Post subject: Re: Pulleys
PostPosted: Mon Jul 16, 2001 2:09 pm
: pulley
The Alt. Pully is the same as the V8 and many suppliers carry it. (the last one I got was from Moroso p/n 64840)
A quick look in my pully barrel tells me that the water pump pulley will be harder to match, I saw that the S.B. Mopar, post 1970 with AC had the same "off-set" but small in diameter, (we want bigger, not smaller)
I would get on the phone and do some asking, I have to think that there is something out there we can use. CV Products is one to check, <A HREF="http://www.cvproducts.com">www.cvproducts.com</A>
or for super trick custom racing stuff, Jones Racing <A HREF="http://www.jonesracingproducts.com">www.jonesracingproducts.com</A>
PostPosted: Mon Jul 16, 2001 3:25 pm
: The Alt. Pully is the same as the V8 and many
: suppliers carry it. (the last one I got was
: from Moroso)
: A quick look in my pully barrel tells me that
: the water pump pulley will be harder to
: match, I saw that the S.B. Mopar, post 1970
: with AC had the same "off-set" but
: small in diameter, (we want bigger, not
: smaller)
: I would get on the phone and do some asking, I
: have to think that there is something out
: there we can use. CV Products is one to
: check, <A HREF="http://www.cvproducts.com">www.cvproducts.com</A>
: or for super trick custom racing stuff, Jones
: Racing <A HREF="http://www.jonesracingproducts.com">www.jonesracingproducts.com</A>
: DD
Thanks Guys for the info I found a Alt pulley made by March now for the waterpump
If it was smaller would it not move more water?
This is for a street car prob never see the strip
so could I get by with a smaller pulley
Thanks again
mrmopar@greganti.com
PostPosted: Mon Jul 16, 2001 10:55 pm
: Thanks Guys for the info I found a Alt pulley
: made by March now for the waterpump
: If it was smaller would it not move more water?
: This is for a street car prob never see the
: strip
: so could I get by with a smaller pulley
Yup, for low RPM "street" cruzing, smaller is better, for higher engine speeds (dragstrip work) bigger is better because that water pump can "eat-up" some H.P. athigh RPM.
