It is currently Sat Jun 20, 2026 4:37 pm
PostPosted: Mon Jul 16, 2007 2:27 pm
hello sl6 sages- must be a battery guru among us. got my 80 volare wagon shipped to fla and am working over different systems. battery looks less than a year old. a 72 month exide. was dead, discharged. wouldnt even light headlights let alone start engine. disconnected and cleaned terminals and posts. slow charged it over night . tester said it had 10 volts. wouldnt accept charge. will sitting for a while 2 mos lets say finish the battery? anything tothe old tale about a battery sitting on concrete floor killing it? thanks bob fisher
This account is used for member help ONLY!
PostPosted: Mon Jul 16, 2007 2:37 pm
Im no guru, but recently had similiar battery problems...
My alternator crapped out, so my battery discharged all the way. Wouldnt hold a charge after that.
Long story short, new battery got me back on the road.
S>
1980 Volare Slant
PostPosted: Mon Jul 16, 2007 2:43 pm
Sounds like the battery may have a bad (shorted cell). Yes, leaving a battery discharged will kill it, but I can't give you a time frame on how long it takes for the battery to die.
Don't assume the battery is only a year old. There should be a sticker with the month and year of manufacture. It's frequently a single letter for the month A being January, B February and a single digit for the year. C5 would be Jan '05 or Jan 1995.
A battery sitting on a concrete floor doesn't hurt the battery. Dirt and moisture on the top of the battery can make for a conductive path that will discharge the battery. Lead-antimony batteries also self-discharge at a fairly high rate which goes up with temperature. On the other end of the scale a discharged battery can freeze and mechanically damage the battery.
I hope this answers your questions!
PostPosted: Wed Jul 18, 2007 9:36 am
I used to have my seldom-used batteries die every year or two; now I use an inexpensive maintainence charger from Harbor Freight (~$14, <<1A, rectified AC regulated @ 14.4V) most of the time.
I got nearly 10 years out of my last Sears Diehard (maybe Silver?) group 27 that way; it may have lasted longer, but my Plymouth's voltage regulator failed and way overcharged the battery on the way back from a show.
The old battery still worked OK until I added water to make up for what was lost while overcharging; then it shorted a cell.
I also tried the de-sulfination pulse modes in my fancy Vector charger on my old batteries, but couldn't ever see any improvement.
