| OK, how flat do you really have to be for metal gasket? https://slantsix.org/forum/viewtopic.php?t=24113 |
| Author: | rock [ Wed Jul 18, 2007 6:03 pm ] |
| Post subject: | OK, how flat do you really have to be for metal gasket? |
OK, How flat do you really have to be for metal gasket? I am still toying with using a metal head gasket under a newly done drool tube head milled .100. This drool head would be replacing a peanut head that was built and milled .030 and put on a block that was milled flat Peanut head and block were driven about 100 miles with the peanut head on a Felpro gasket. Is the block too warped now (never over 190 degrees and less than 100 miles) to try a metal gasket without re milling the block? I hate to give up that Felpro thickness, and besides, my Felpro leaked. rock 64d100 |
| Author: | Doc [ Wed Jul 18, 2007 6:12 pm ] |
I think getting the used surface clean will be the issue. Once clean of old gasket material, sanding with a 'long board' and using a light coat of spray sealer should work well to seal it. DD |
