It is currently Wed Nov 18, 2026 2:14 am
 Post subject: knocking noise
PostPosted: Mon Jul 09, 2007 12:38 am
When I did the valve adjustment I didn’t have a mess of oil like there should be. I had noticed before I took it apart that my pressure wasn't has high has it normally was. I developed a loud knocking noise. I had two mechanics tell me it was my rockers. Seeing has I’ve had the car for over 3 years I never had the valves adjusted. so I took every thing apart cleaned it all up but I didn’t realize that there is a front and back side of the bar the service manual says there’s a flat part on the bar I didn’t see any thing but I really wasn’t looking for that . After things were put back together the knock is still there. I noticed the damper looks like it was wobbling and the belt is worn on one side. I did notices a power difference after the adjustment.
My next thing to check is the converter. What’s the best way I can check with out removing the pan if there is such a way?
Has for the low oil pressure I’m going to check the pump. I do have an oil leak that seems to be coming from there. Even with the leak before I still had good pressure until recently.
Timing chain will be next if the knock is not form the converter and then on to the bearings.
PostPosted: Mon Jul 09, 2007 1:46 am
The only way i know to check the converter bolts(they cause the rod knock noise) is to pull the access pan and tighten them. if there is another way i would like to know too!
Even in moderation i am excessive!
PostPosted: Mon Jul 09, 2007 10:28 am
The cover bolts are easy to check once you take the dust cover off the bottom/front of the bellhousing.
PostPosted: Mon Jul 09, 2007 9:20 pm
thanks Doc i don't know why i didn't think about the dust cover. thats why i had to ask. does the starter need to come off to take the cover off? it looks like it does. but not sure. i'm sure i'll find out tomorrow.
PostPosted: Thu Jul 19, 2007 3:28 pm
well takeing the dust cover was easy and i checked the bolts and the all seem to be tight to specs. there is one bolt the is round and was hard to check. i still have the knock so now im movein to the chain.
to i have to take out the Radiator to get the the cover off. i'm getting the tool to remove the dambner. thats a nother thing if you look at it when i's moving it wobowls and the belt looks a little worn.
Users browsing this forum: Bing [Bot] and 8 guests
