It is currently Fri May 15, 2026 4:45 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: milk anyone??
PostPosted: Thu Jul 19, 2001 12:32 am
well, after 3 weeks of driving my new val, the dreaded waterey oil has come back worse than ever (im sure its the block this time)
since im a little short of the folding stuff at the moment ill bang a Hemi in it, and save up some cash to do a proper rebuild this time.
i have 4 225 slants available to me for nothing and was wondering which might be the best to use?
1. 5 welchplug, 2806830 - 3
2. 3 welchplug, 2463430 - 13
3. 5 welchplug, 2806830 - 1
4. 3 welchplug, 2463430 - 12
i read up about them in that article on this site, so the 5 plug ones better should be better, but they have low numbers after the dash, i heard that the higher the better??
or i could rebuild and sleeve the current one
5. 3 welchplug, 2463430 - 19!
i think i saw a "BH" on one of them, would this be the one to use overall the others, even if it does have the lowest dash number??
thanx, its not like it'll be a fulltime racer, just a cruise/tow/quick streetcar
Mr_Mopar_Man@hotmail.com
 Post subject: Re: milk anyone??
PostPosted: Thu Jul 19, 2001 12:35 am
: thanx, its not like it'll be a fulltime racer,
: just a cruise/tow/quick streetcar
opps, sorry didnt finish.. it wont be a fulltime racer like i said, but who knows what the future may bring!
PostPosted: Thu Jul 19, 2001 10:15 am
: Well, after 3 weeks of driving my new val, the
: dreaded waterey oil has come back worse than
: ever (im sure its the block this time)
: Since im a little short of the folding stuff at
: the moment ill bang a Hemi in it, and save
: up some cash to do a proper rebuild this
: time.
: I have 4 225 slants available to me for nothing
: and was wondering which might be the best to
: use?
: 1. 5 welchplug, 2806830 - 3
: 2. 3 welchplug, 2463430 - 13
: 3. 5 welchplug, 2806830 - 1
: 4. 3 welchplug, 2463430 - 12
: I read up about them in that article on this
: site, so the 5 plug ones should be
: better, but they have low numbers after the
: dash, I heard that the higher the better??
: or I could rebuild and sleeve the current one
: 5. 3 welchplug, 2463430 - 19!
: I think I saw a "BH" on one of them,
: would this be the one to use overall the
: others, even if it does have the lowest dash
: number??
The dash numbers are a "link" to the casting pattern equipment used to produce the block... that's all.
As you are seeing, there were a bunch of casting patterns used but no-one (including myself) can pin-point a single "dash #" as the "best". There are just too many patterns & variables, seeing that each sand mold is basically "hand-made" off the pattern equipment, then each "pour" is out of a "melt" of cast iron made-up that day. (or shift) If you think all these sand molds & "batches" of cast iron come-out the same, melt to melt, think again! (you would be amazed on how the foundry makes the metal, basically they just "dump" train-car loads of scrap into the furnace(s), melt it down, check the chemistry ("taste the soup") and then "adjust" as needed. (throw-in some other "known" stuff, kinda like adding a pinch of salt to the soup) Needless to say, the dash numbers are just a referance point, it is up to you to do some carefull inspection and testing to find that "best" block.
I try to share all the info. I collect, I have inspected 20-30 of these SL6 blocks over the years so that's a start. (I have about 11,999,970 more to look at, based on the 12 million produced!) I do feel the "5-plug" ones are stronger so start with those. Also that the "BH" blocks with the additional "pencil ribs" would add a bit more stiffness *if* everything else was equal.
I have seen these added ribs in different thicknesses and other little "interesting" casting fetures so do what the article says, clean-up and inspect a few "5 plug" blocks, your "best" one will present it's self as you look them over "side by side". (I find that the selection is based on "wow, I don't like that flaw" and you set-aside that block, then it becomes a hard choice between the "good ones" remaining.(and most of them are "good")
Here is a look at the "BH" with added ribs I just built-up for the dragcar. - DD
Sl6 Block Article
