| 4 spd trans swap into '66 Val wagon https://slantsix.org/forum/viewtopic.php?t=2417 |
| Author: | Gary L [ Tue Jul 17, 2001 9:15 pm ] |
| Post subject: | 4 spd trans swap into '66 Val wagon |
I just found a 4 speed from a 1977 Dodge D100 short bed half-ton pickup, with a /6, at a local salvage yard. Will it swap into my 1966 Valiant wagon, which currently has a 225 /6 from a ‘75 Aspen? What other parts should I grab from the donor truck ( i.e. shift linkage, bellhousing, clutch, etc)? Will I need to change crossmember that holds up the trans? Are there any modifications that I need to do (i.e. shorten the drive shaft)? Will a floor hump from a Duster ,which had a 3 speed on the floor, work? What parts do I need to buy new when I do the swap (i.e. clutch, throw-out bearing, etc? Any tips would be appreciated. Please email me at <A HREF="mailto:theluketribe@hotmail.com">theluketribe@hotmail.com</A>. Thanks, Gary L theluketribe@hotmail.com |
| Author: | Doug Ahern [ Wed Jul 18, 2001 10:14 am ] |
| Post subject: | Re: 4 spd trans swap into '66 Val wagon |
: I just found a 4 speed from a 1977 Dodge D100 : short bed half-ton pickup, with a /6, at a : local salvage yard. Will it swap into my : 1966 Valiant wagon, which currently has a : 225 /6 from a ?75 Aspen? What other parts : should I grab from the donor truck ( i.e. : shift linkage, bellhousing, clutch, etc)? : Will I need to change crossmember that holds : up the trans? Are there any modifications : that I need to do (i.e. shorten the drive : shaft)? Will a floor hump from a Duster : ,which had a 3 speed on the floor, work? : What parts do I need to buy new when I do : the swap (i.e. clutch, throw-out bearing, : etc? Any tips would be appreciated. Please : email me at <A HREF="mailto:theluketribe@hotmail.com">theluketribe@hotmail.com</A> . there were two type of 4spds installed in trucks in those years. one is the A-833 overdrive 4spd which is basically a passenger car 4spd and shifts like one. The other 4spd is the A435 which is a huge truck 4spd that shifts like a truck with a truck "granny low". the 435 requires a huge bellhousing (BH) and a 143 tooth flywheel. the combo of the BH and the 435 wouldn't fit in an A-body unless you hacked the firewall and the trans tunnel to pieces,,, and of course the shift knob of a 435 would probably bang into the rear view mirror on a A-body If its an 833 in a truck, its a long tailshaft 833 unit and it won't really work in an A-body. It could be made to fit, but it would require significant modifications: the trans mount on long tailshaft 4spd (B/E/truck) sits farther back than the A/F body 4spd so a custom lower crossmember would have to be fabricated. A long tailshaft 4spd in an A-body will place the shifter directly in the path of the upper crossmember that goes up and over the trans and joins the the two t-bar mount frame rails. you'd have to cut this crossmember and either try to build a second one behind or ahead of the old one, or drive without one (not advised at all!). It might still be worth while to grab the long tailshaft OD 4psd to raise funds for the A/F body unit. The A/F OD 833 is much more common than the B/E/truck 4spd. they sell for $60-125 when priced right. They used to sell for $25-60 just a few years ago, but then Hot Rod magazine (and a few other rags) labeled them "rare and exciting" and the price doubled. lets say you find an A/F OD 833 to install in your early A!!! Here is the lowdown: your 66 driveshaft will work, no problemo. you'll need a 75-80 6 3spd/4spd BH, dust shield and inspection plate along with the matching clutch fork (note the OD BH clutch fork is the long one that was also used on LA V8 BH's. and not the smaller 6 fork used on sixties G/RG 3spds and 4spds). you'll also need to the right flywheel to mate to your 75 crank... (question for Doc. Dodge: what year did the 6 crank flange flywheel/flexplate bolt pattern change?) if nothing else I can tell you that your 75 crank will not work with a 67 or earlier flywheel (center register is sized different). the A/F body G/RG BH requires a smaller 124-some-odd tooth flywheel that was used on all passenger car 6 3spds and 4spds. I think the truck OD BH used a larger flywheel, perhaps a 130 or 143 tooth unit. if you are currently running an automatic: you need a 63-66 A-body clutch pedal setup, your crankshaft needs a pilot bushing, and you need to cut a big hole in the floor to accomodate the 4spd shifter and shift rods. Of course, you'll need to cover this hole, the 4spd hump to use is the 64-66 4spd A-body hump with can be somewhat elusive, but not impossible to find (there was one at Carlisle last week for $85, Brewers used to produce fibreglass repros, and I've seen 3 in junkyards in the last 3-4 years...). It doesn't have to be an original hump, you could fabricate a suitable cover out of sheet metal. you also need a 63-66 3spd/4spd z-bar (torque shaft). there are a bunch of other small details I'll be glad to go into if after all this you are still interested in talking about it... by the way:if you had gone to Carlisle last week with the idea of collecting all the required parts to "OD-4spd-ize" an A-body, you could have done it for anywhere from $200 to $500 for everything.... Included URL has some 4spd A-body info and trans ID info... good luck! Doug Ahern Athens GA: http://www.autohobbydigest.com/ablues-2.html doug@autohobbydigest.com |
| Author: | richard [ Wed Jul 18, 2001 11:44 am ] |
There are two mounting points for the shifter on the long tailshaft 833 tranny. One is right at teh tail and one is where it would be on the flange tail shaft 833 tranny (Ie same length from the nose of the inputshaft.) Howcome they made the stinger housing out of castiron? Has anyone ever seen an aluminum one? I will be slapping in the od tranny in my 63 over the winter. First I need to reassemble it! Good luck, let me know how it goes.. Quote:
: : there were two type of 4spds installed in : trucks in those years. one is the A-833 : overdrive 4spd which is basically a : passenger car 4spd and shifts like one. The : other 4spd is the A435 which is a huge truck : 4spd that shifts like a truck with a truck : "granny low". the 435 requires a : huge bellhousing (BH) and a 143 tooth : flywheel. the combo of the BH and the 435 : wouldn't fit in an A-body unless you hacked : the firewall and the trans tunnel to : pieces,,, and of course the shift knob of a : 435 would probably bang into the rear view : mirror on a A-body : identification: the 435's shifter is : integrated into the top of the trans, on a : 833 OD, the shifter is side hung on the : tailshaft and the trans is a side loader. : : If its an 833 in a truck, its a long tailshaft : 833 unit and it won't really work in an : A-body. It could be made to fit, but it : would require significant modifications: the : trans mount on long tailshaft 4spd : (B/E/truck) sits farther back than the A/F : body 4spd so a custom lower crossmember : would have to be fabricated. A long : tailshaft 4spd in an A-body will place the : shifter directly in the path of the upper : crossmember that goes up and over the trans : and joins the the two t-bar mount frame : rails. you'd have to cut this crossmember : and either try to build a second one behind : or ahead of the old one, or drive without : one (not advised at all!). It might still be : worth while to grab the long tailshaft OD : 4psd to raise funds for the A/F body unit. : The A/F OD 833 is much more common than the : B/E/truck 4spd. they sell for $60-125 when : priced right. They used to sell for $25-60 : just a few years ago, but then Hot Rod : magazine (and a few other rags) labeled them : "rare and exciting" and the price : doubled. : : lets say you find an A/F OD 833 to install in : your early A!!! Here is the lowdown: your 66 : driveshaft will work, no problemo. you'll : need a 75-80 6 3spd/4spd BH, dust shield : and inspection plate along with the matching : clutch fork (note the OD BH clutch fork is : the long one that was also used on LA V8 : BH's. and not the smaller 6 fork used on : sixties G/RG 3spds and 4spds). you'll also : need to the right flywheel to mate to your : 75 crank... (question for Doc. Dodge: what : year did the 6 crank flange : flywheel/flexplate bolt pattern change?) if : nothing else I can tell you that your 75 : crank will not work with a 67 or earlier : flywheel (center register is sized : different). the A/F body G/RG BH requires a : smaller 124-some-odd tooth flywheel that was : used on all passenger car 6 3spds and : 4spds. I think the truck OD BH used a larger : flywheel, perhaps a 130 or 143 tooth unit. : : if you are currently running an automatic: you : need a 63-66 A-body clutch pedal setup, your : crankshaft needs a pilot bushing, and you : need to cut a big hole in the floor to : accomodate the 4spd shifter and shift rods. : Of course, you'll need to cover this hole, : the 4spd hump to use is the 64-66 4spd : A-body hump with can be somewhat elusive, : but not impossible to find (there was one at : Carlisle last week for $85, Brewers used to : produce fibreglass repros, and I've seen 3 : in junkyards in the last 3-4 years...). It : doesn't have to be an original hump, you : could fabricate a suitable cover out of : sheet metal. you also need a 63-66 3spd/4spd : z-bar (torque shaft). : : there are a bunch of other small details I'll : be glad to go into if after all this you are : still interested in talking about it... by : the way:if you had gone to Carlisle last : week with the idea of collecting all the : required parts to "OD-4spd-ize" an : A-body, you could have done it for anywhere : from $200 to $500 for everything.... : : Included URL has some 4spd A-body info and : trans : ID info... : : good luck! : : Doug Ahern : Athens GA: richard-c@e-d-a.com |
| Author: | Gary L [ Wed Jul 18, 2001 1:58 pm ] |
Thanks for your response Doug. Now I'm bummed. The search for an A/F body A-833 continues. Thanks, Gary P.S. What is a F body. Quote:
: : there were two type of 4spds installed in : trucks in those years. one is the A-833 : overdrive 4spd which is basically a : passenger car 4spd and shifts like one. The : other 4spd is the A435 which is a huge truck : 4spd that shifts like a truck with a truck : "granny low". the 435 requires a : huge bellhousing (BH) and a 143 tooth : flywheel. the combo of the BH and the 435 : wouldn't fit in an A-body unless you hacked : the firewall and the trans tunnel to : pieces,,, and of course the shift knob of a : 435 would probably bang into the rear view : mirror on a A-body : identification: the 435's shifter is : integrated into the top of the trans, on a : 833 OD, the shifter is side hung on the : tailshaft and the trans is a side loader. : : If its an 833 in a truck, its a long tailshaft : 833 unit and it won't really work in an : A-body. It could be made to fit, but it : would require significant modifications: the : trans mount on long tailshaft 4spd : (B/E/truck) sits farther back than the A/F : body 4spd so a custom lower crossmember : would have to be fabricated. A long : tailshaft 4spd in an A-body will place the : shifter directly in the path of the upper : crossmember that goes up and over the trans : and joins the the two t-bar mount frame : rails. you'd have to cut this crossmember : and either try to build a second one behind : or ahead of the old one, or drive without : one (not advised at all!). It might still be : worth while to grab the long tailshaft OD : 4psd to raise funds for the A/F body unit. : The A/F OD 833 is much more common than the : B/E/truck 4spd. they sell for $60-125 when : priced right. They used to sell for $25-60 : just a few years ago, but then Hot Rod : magazine (and a few other rags) labeled them : "rare and exciting" and the price : doubled. : : lets say you find an A/F OD 833 to install in : your early A!!! Here is the lowdown: your 66 : driveshaft will work, no problemo. you'll : need a 75-80 6 3spd/4spd BH, dust shield : and inspection plate along with the matching : clutch fork (note the OD BH clutch fork is : the long one that was also used on LA V8 : BH's. and not the smaller 6 fork used on : sixties G/RG 3spds and 4spds). you'll also : need to the right flywheel to mate to your : 75 crank... (question for Doc. Dodge: what : year did the 6 crank flange : flywheel/flexplate bolt pattern change?) if : nothing else I can tell you that your 75 : crank will not work with a 67 or earlier : flywheel (center register is sized : different). the A/F body G/RG BH requires a : smaller 124-some-odd tooth flywheel that was : used on all passenger car 6 3spds and : 4spds. I think the truck OD BH used a larger : flywheel, perhaps a 130 or 143 tooth unit. : : if you are currently running an automatic: you : need a 63-66 A-body clutch pedal setup, your : crankshaft needs a pilot bushing, and you : need to cut a big hole in the floor to : accomodate the 4spd shifter and shift rods. : Of course, you'll need to cover this hole, : the 4spd hump to use is the 64-66 4spd : A-body hump with can be somewhat elusive, : but not impossible to find (there was one at : Carlisle last week for $85, Brewers used to : produce fibreglass repros, and I've seen 3 : in junkyards in the last 3-4 years...). It : doesn't have to be an original hump, you : could fabricate a suitable cover out of : sheet metal. you also need a 63-66 3spd/4spd : z-bar (torque shaft). : : there are a bunch of other small details I'll : be glad to go into if after all this you are : still interested in talking about it... by : the way:if you had gone to Carlisle last : week with the idea of collecting all the : required parts to "OD-4spd-ize" an : A-body, you could have done it for anywhere : from $200 to $500 for everything.... : : Included URL has some 4spd A-body info and : trans : ID info... : : good luck! : : Doug Ahern : Athens GA: theluketribe@hotmail.com |
| Author: | Doug Ahern [ Wed Jul 18, 2001 2:31 pm ] |
: There are two mounting points for the shifter : on the long tailshaft 833 tranny. One is : right at teh tail and one is where it would : be on the flange tail shaft 833 tranny (Ie : same length from the nose of the : inputshaft.) Howcome they made the stinger : housing out of castiron? Has anyone ever : seen an aluminum one? Yeah, the front shifter pad is for B-body and the rear is for the E-body. The only aluminum 4spd housings I know of.... lets see, there were some aluminum OD units, most were cast iron... Direct Connection made an aluminum case back in the seventies, rare as hen's teeth now and expensive to boot! doug@autohobbydigest.com |
| Author: | richard [ Wed Jul 18, 2001 2:36 pm ] |
: Yeah, the front shifter pad is for B-body and : the rear is for the E-body. The only : aluminum 4spd housings I know of.... lets : see, there were some : aluminum OD units, most were cast iron... : Direct Connection made an aluminum case back : in the seventies, rare as hen's teeth now : and expensive to boot! When I sat the non OD next to the OD tranny, that front pad looked like it was in the same place. Let me look again. The main case on my OD is aluminum. The tail is cast iron. Did anyone ever make an aluminum tail section? I was just curious. richard-c@e-d-a.com |
| Author: | DusterIdiot [ Wed Jul 18, 2001 6:21 pm ] |
Let me try and wade through this topic, because it's a good one. The first OD units to arrive on the scene in 1975 I hear came with cast iron housings (and some in 76 also). I hear all the units after 76 are aluminum (including the tailshafts.) The close ratio 4-spds for cars got redesignated A-822 according to the 1976 Service Manual specs (never seen one). Not all truck OD tranny's came with long tailshafts, in the last of the slant truck run about the mid 80's, Dodge put "short" boxes into their trucks. I know this because I just rebuilt a 1987 dated A-833OD tranny for my Feather Duster (installed by the previous owner). You may have more luck in that year range of Dodge Ram for a better fit. (You should still be able to use the bellhousing from any 75+ truck/car with 4-spd or 3-spd). hope that helps, -DusterIdiot P.S. Gary, I still have that Super Six for ya, I will be in your area visiting family on Aug.19th, e-mail me. res0aus2@verizon.net |
| Author: | richard [ Thu Jul 19, 2001 1:32 pm ] |
Now I am more confused than ever. My tail shaft housing is castiron and heavy. The close ratio old box only has one shifter pad so I assumed that the position for A and B body pads was the same. ANd it looked that way on the OD next to the standard, although I may have been loosinatin. Maybe I should rad the archives. Quote:
: : Let me try and wade through this topic, because : it's a good one. : : The first OD units to arrive on the scene in : 1975 I hear came with cast iron housings : (and some in 76 also). I hear all the units : after 76 are aluminum (including the : tailshafts.) The close ratio 4-spds for cars : got redesignated A-822 according to the 1976 : Service Manual specs (never seen one). : Not all truck OD tranny's came with long : tailshafts, in the last of the slant truck : run about the mid 80's, Dodge put : "short" boxes into their trucks. I : know this because I just rebuilt a 1987 : dated A-833OD tranny for my Feather Duster : (installed by the previous owner). You may : have more luck in that year range of Dodge : Ram for a better fit. (You should still be : able to use the bellhousing from any 75+ : truck/car with 4-spd or 3-spd). : : hope that helps, : : -DusterIdiot : : P.S. Gary, I still have that Super Six for ya, : I will be in your area visiting family on : Aug.19th, : e-mail me. richard-c@e-d-a.com |
| Author: | DusterIdiot [ Thu Jul 19, 2001 2:16 pm ] |
: Now I am more confused than ever.
Welcome to the old car, frankenstein/rubik's cube of the parts world. My tail shaft housing is castiron and heavy. Anybody, even the factory could have picked one out of a bin of tailshafts and installed it, or...someone in the past broke the tailshaft and got their hands on an iron one. (Would be more durable...). and most of the parts mix and match. The close ratio old box only has one shifter pad so I assumed that the position for A and B body pads was the same. ANd it looked that way on the OD next to the standard. The A and later F-body(aspen/ volare) boxes are the same dimension wise and have the pad pattern in the same spot on the tailshaft. They mimic the same length as a A-904/998/999 automatic. B and E body tailshafts are longer, as they have to mimic the length of the A-727, and the shift pads are usually toward the casing, not on the driveshaft end like the A/F). Most Truck tailshafts are 4" longer than the B/E tailshafts (Some of these have dual patterns for different applications...). Hope that's as clear as mud... -DusterIdiot res0aus2@verizon.net |
