Rear Trans. Mount?
https://slantsix.org/forum/viewtopic.php?t=24184
Author:  64A100 [ Tue Jul 24, 2007 12:04 am ]
Post subject:  Rear Trans. Mount?
I'm looking for a rear trans. mount for my '64 A-100 van. Mine's a little sloppy and I'm wondering if it caused a pretty new rear trans. seal to start leaking real bad. I'm told new mounts aren't avail for a '64.
Any suggestions?
Thanks,
Tom
Author:  Jeffc [ Tue Jul 24, 2007 8:25 am ]
Here is the OEM part number from my truck 66 parts book
2508 321
Just maybe it will cross to cars, but may not.
It is listed as a A100 only item.......
A good used one may be your only option.
Might try http://wildcatmopars.com/
they have a few A100's to part out.
Might check ebay as there are some pretty odd things that
show up from time to time.
http://engine-swaps.com/frames/frame_Homepage.html
this outfit also has some mounts that no one else has.
Also might drop into one of the truck sites and post a parts want.
http://www.sweptline.org/
http://pub36.bravenet.com/forum/show.ph ... 3079965801
Most rear seal issues I have seen have more to do with
driveline balance issues and small burrs on the slip yoke,
but a bad mount could cause it if the mount were very sloppy.
Author:  Charrlie_S [ Tue Jul 24, 2007 11:28 am ]
Post subject:  Re: Rear Trans. Mount?
Any suggestions?
Thanks,
Tom
I may have found one NOS mount number 2508321, for you. I will send you a PM, with the contact info, since there is only one.
Author:  Jeffc [ Tue Jul 24, 2007 1:43 pm ]
:shock: good find Charrlie_S ---------
there you go, that is why I took the time to look up that
number, never know whats out there.
Just be sure to compare it to yours, if possable, before you
buy :D
Author:  64A100 [ Wed Jul 25, 2007 7:41 am ]
Thanks for the help guys, I'll let you know if it's the same mount.
Tom
