who's installed their Erson cam and driven it?
https://slantsix.org/forum/viewtopic.php?t=24236
Author:  64'4$peed [ Fri Jul 27, 2007 10:42 am ]
Post subject:  who's installed their Erson cam and driven it?
I got a 270 in my new motor. It runs well but the timing curve is off. 1000-2000 RPMs is a little sluggish then feels like I got a turbo and the boost kicked in between 2000-4000 RPM. 2bbl carb, dutra duals, and some porting of the head. this is infront of a t5 and 3.91's. Any other Ersons running?
Author:  Bren67Cuda904 [ Fri Jul 27, 2007 11:20 am ]
I believe that cam has a 2000 -5000rpm range.
Author:  Doc [ Fri Jul 27, 2007 11:27 am ]
What is the static compression ratio of your engine?
Author:  64'4$peed [ Fri Jul 27, 2007 12:43 pm ]
I figured it out a while ago. I cant remember exactly but its around 9-1
Author:  Doctor Dodge [ Fri Jul 27, 2007 9:13 pm ]
Can you run a compression test and give us cranking compression in psi?
