| Brake Booster https://slantsix.org/forum/viewtopic.php?t=2426 |
| Author: | Mike P [ Fri Jul 20, 2001 11:26 am ] |
| Post subject: | Brake Booster |
When converting to power brakes, besides needing the booster, MC, and P valve, do you also need lever assembly and push rod that attach to back of bosster? If so, can it be purchased new or is it a swap meet/JYard item? Thanks |
| Author: | r [ Mon Jul 23, 2001 12:35 am ] |
| Post subject: | Re: Brake Booster |
: When converting to power brakes, besides : needing : the booster, MC, and P valve, do you also need : lever assembly and push rod that attach to back : of bosster? If so, can it be purchased new : or is it a swap meet/JYard item? : Thanks you need everything but the pedal/lever assembly. Jyard is best bet. fits right in your tool box and looks like a driver/punch (not that I ever did that/recomend it) Most yards won't even charge you for it. richard-c@e-d-a.com |
| Author: | Mike P [ Mon Jul 23, 2001 5:16 am ] |
| Post subject: | Re: Thanks! *NM* |
