| Cam oiling groove ?? https://slantsix.org/forum/viewtopic.php?t=24281 |
| Author: | HyperValiant [ Mon Jul 30, 2007 7:50 pm ] |
| Post subject: | Cam oiling groove ?? |
I have one the Erson cams with the mis-drilled oiling hole and decided to groove the rear cam journal to get as much oil to the top as possible. In Docs "Twiggy" post he suggested a .020x.020 groove. My question is what is the best way to cut this groove ? Can it be done by hand or does it need to be done on a lathe? Thanks in advance. HyperValiant |
| Author: | Doctor Dodge [ Mon Jul 30, 2007 11:27 pm ] |
You can do it by hand but it is best to use a bearing, slid 1/2 way onto the journal, as a guide. Wrap some tape on the other side of the exposed journal so it leaves an exposed gap to cut (grind) your groove in. DD |
| Author: | HyperValiant [ Tue Jul 31, 2007 7:15 pm ] |
Do you do it with a file or can you use an air powered cut off wheel? HyperValiant |
| Author: | Doctor Dodge [ Tue Jul 31, 2007 10:33 pm ] |
For this job, I use my variable speed Dremal tool with a small abrasive "cut-off" wheel. I find that my air powered die grinder and "wizzer wheel" is too aggressive for the job. DD |
