| How to build a 14 second /6 https://slantsix.org/forum/viewtopic.php?t=24300 |
| Author: | carpdar [ Wed Aug 01, 2007 5:00 pm ] |
| Post subject: | How to build a 14 second /6 |
Anyone have any pointers where to start and where to go to get my stock 225 running 14's? |
| Author: | Matadem [ Wed Aug 01, 2007 5:05 pm ] |
go turbo.... cheaper in the end....... |
| Author: | slantvaliant [ Wed Aug 01, 2007 5:19 pm ] |
Quote: go turbo.... cheaper in the end.......
... and put it in a rail
| Author: | slantzilla [ Wed Aug 01, 2007 5:22 pm ] |
Build a 16 second Slant and hit it with a 100 shot of spray. 14's aren't too hard on motor. You just have to use a sensible plan. Bolting in a big cam and leaving everything else stock isn't going to do it. You need most of all a good head. Bigger valves and bowl porting are a good place to start. The rest is just a good balance of compression, cam, intake, carb, headers, etc. The you need a good converter and trans if you run an automatic. Upgrade the rear with some decent gears, my favorite is a 3.91. Then, make the car as light as safely possible. You can also easily spray a 14 second Slant into the 12's. |
| Author: | VG-265 [ Thu Aug 02, 2007 5:02 am ] |
14 pounds of BOOST! |
| Author: | Greg Ondayko [ Thu Aug 02, 2007 6:11 am ] |
Quote: You need most of all a good head. Bigger valves and bowl porting are a good place to start. Eliminating All uneccsary Weight Will help too - Espically if it's a Drag Only car!! Greg |
| Author: | featherduster76 [ Sun Aug 05, 2007 2:36 pm ] |
Good head, weight reduction wherever possible, decent and or low gear set in the back and then you wont be to far off. A nice cam and converter will work wonders as well. |
| Author: | Charrlie_S [ Sun Aug 05, 2007 8:04 pm ] |
Get the weight down to about 2,700 lbs or less. The less weight the faster/easier it will be. What will be the purpose of the car? Street only, street and ocasional track, mostly track, or dedicated race car? You need to define the perameters. |
| Author: | argentina-slantsixer [ Sun Aug 05, 2007 8:10 pm ] |
go spend thousands and thousands of dollars in a big cubes stroker slant... I heard they outrun 440's (sorry, I couldn't resist, sad thing is that I'm on the same path, big cubes motor with lots of money on it... I think my sarcasm is truly fear) |
| Author: | Bren67Cuda904 [ Sun Aug 05, 2007 8:57 pm ] |
Hey Hey Hey there buddy. I am standing right here. |
