electronic distributor
https://slantsix.org/forum/viewtopic.php?t=24346
Author:  icaneat50eggs [ Sun Aug 05, 2007 5:02 pm ]
Post subject:  electronic distributor
My electronic distributor has two pick ups, is this normal? I thought they only had one.
Author:  DusterIdiot [ Sun Aug 05, 2007 5:26 pm ]
Post subject:  Late model aka ESC distributor...
The two pick up variety is for the late truck and van slants with the ESC /Lean Burn setup...the early 80's versions had only one pickup in them ...but both are 'static' in timing (you have no advance mechanism in it...).
If this is a car, swap it out for a standard one, or if you were junkyarding, look at something in the late 70's time frame (car or truck).
Author:  icaneat50eggs [ Sun Aug 05, 2007 5:36 pm ]
Thanks. It came with an engine/trans that I bought. No way to make it work? Replace the pick ups with a single one? Just junk it?.
Author:  SlantSixDan [ Sun Aug 05, 2007 6:00 pm ]
Yup, throw it out. The dual-pickup distributors don't have conventional advance mechanisms.
Author:  DusterIdiot [ Sun Aug 05, 2007 10:04 pm ]
Post subject:  Errr... put in box on back shelf...
Yup, throw it out.
Actually , if you are going to go with an EFI setup later in life and are using a system that can use a stock style 'locked out' distributor, that would make a good candidate (the Holley system I have will need the 1981 Dodge distributor with the single pick up I have stuffed away). Otherwise, it's a 'pitcher'...
Author:  icaneat50eggs [ Sun Aug 05, 2007 10:20 pm ]
Thanks, guys. Its too bad, this is really tight bearing wise.
Author:  Matt Cramer [ Mon Aug 06, 2007 7:35 am ]
It wouldn't surprise me if one of the EFI guys here could use it. Might want to post it in the For Sale section. I'm running a Lean Burn distributor on my Dart.
