It is currently Sat May 09, 2026 6:08 pm
 Post subject: electronic distributor
PostPosted: Sun Aug 05, 2007 5:02 pm
My electronic distributor has two pick ups, is this normal? I thought they only had one.
Excuse me, does this smell like chloroform to you?
PostPosted: Sun Aug 05, 2007 5:26 pm
The two pick up variety is for the late truck and van slants with the ESC /Lean Burn setup...the early 80's versions had only one pickup in them ...but both are 'static' in timing (you have no advance mechanism in it...).
If this is a car, swap it out for a standard one, or if you were junkyarding, look at something in the late 70's time frame (car or truck).
PostPosted: Sun Aug 05, 2007 5:36 pm
Thanks. It came with an engine/trans that I bought. No way to make it work? Replace the pick ups with a single one? Just junk it?.
PostPosted: Sun Aug 05, 2007 6:00 pm
Yup, throw it out. The dual-pickup distributors don't have conventional advance mechanisms.
PostPosted: Sun Aug 05, 2007 10:04 pm
Yup, throw it out.
Actually , if you are going to go with an EFI setup later in life and are using a system that can use a stock style 'locked out' distributor, that would make a good candidate (the Holley system I have will need the 1981 Dodge distributor with the single pick up I have stuffed away). Otherwise, it's a 'pitcher'...
PostPosted: Sun Aug 05, 2007 10:20 pm
Thanks, guys. Its too bad, this is really tight bearing wise.
PostPosted: Mon Aug 06, 2007 7:35 am
It wouldn't surprise me if one of the EFI guys here could use it. Might want to post it in the For Sale section. I'm running a Lean Burn distributor on my Dart.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
