| tranny mounts https://slantsix.org/forum/viewtopic.php?t=24375 |
| Author: | oibrownskin [ Tue Aug 07, 2007 5:09 pm ] |
| Post subject: | tranny mounts |
I lost the transmission bolts that attach through the cross member bracket and through the frame. where can I get more? Caesar |
| Author: | slantzilla [ Tue Aug 07, 2007 6:27 pm ] |
IIRC, they are 7/16"X1" coarse thread. Should be able to get some at any parts store. |
| Author: | HyperValiant [ Tue Aug 07, 2007 8:16 pm ] |
I think you are talking about the long bolts that pass through the crossmember and holds the mount to the torsion bar crossmember. If this is the case,measure the width of the crossmember and diameter of the hole and go to your local hardware store or farm supply store and they should have what you need. HyperValiant |
| Author: | oibrownskin [ Wed Aug 08, 2007 7:30 pm ] |
| Post subject: | thanks |
Yea the bolt I was going to use as a reference I LOST!!! ARRGHH!!! I will just measure tonight and go to home depot (i work there, so convenient as all hell) and get 4 of each thing, maybe 8 washers though. Thanks, Caesar |
| Author: | slantzilla [ Wed Aug 08, 2007 9:00 pm ] |
Sorry, I posted the trans mount to trans bolts. Crossmember bolts are 1/2"X4" for the early A body and 3/8"X4" for the later A body. 4 each, but you can get away with 2. |
| Author: | Charrlie_S [ Thu Aug 09, 2007 5:37 am ] |
Quote: 4 each, but you can get away with 2.
Saves weight on a race car. |
| Author: | slantzilla [ Thu Aug 09, 2007 9:37 am ] |
