Bolt size for water neck?
https://slantsix.org/forum/viewtopic.php?t=24430
Author:  Mag00 [ Sat Aug 11, 2007 1:52 pm ]
Post subject:  Bolt size for water neck?
Ok, have a laugh, I was in process of R%R on belts hoses plugs, etc to be ready in plenty of time for a TNT or two before the Redding deal... Knowing that the FLAPS therastats can be an iffy proposition, I removed the one in the vehicle and tested it and was fine ... opened at 3 degrees off off the stamped number... Great! now i checked all the ancillaries and the neck looked a little suspect... pitting around the capyure point ... got a new one only had to wait a day went to install.. ooopppsss! unpainted part , won;t do! took one of the neck bolts to get a good color match... now I can't find either bolt nor the good thermo.. I have a new 'stat, but need to know what size bolts do I need to procure? thank you Doofus in Sac
Author:  slantzilla [ Sat Aug 11, 2007 2:39 pm ]
3/8"X1" or 1-1/4" if you can find them. Coarse thread, of course. :D
