Holley carb ?
https://slantsix.org/forum/viewtopic.php?t=24451
Page 1 of 1
Author:  Charrlie_S [ Mon Aug 13, 2007 4:08 pm ]
Post subject:  Holley carb ?
Converting my 390 Vac sec 4bbl from a metering plate to a metering block. That way I can adjust the sec main jet size. Can anyone help with the equivilant jet size for a metering plate with the numbers 54?9716B so I have a baseline? The question mark in the number is an unreadable charater.
Author:  DusterIdiot [ Mon Aug 13, 2007 7:39 pm ]
Post subject:  The numbers...
How old is this carb?
The newer 90's ish carbs just have a number stamped on it like '34'.
The older part number system used to start with '34BP'-XXXX-(two digit plate number).
There is another set of plates that were just stamped '34BP-(4 digit part number).
Author:  Charrlie_S [ Thu Aug 16, 2007 5:06 am ]
Thanks, DI. The first numbers were 34. When I removed the plate from the carb, I could see it better. Also found the jet size stamped on the plate. Hard to see as it was faint and on a casting line. # 59
