| Ticking https://slantsix.org/forum/viewtopic.php?t=24468 |
| Author: | 63mopar [ Tue Aug 14, 2007 7:54 pm ] |
| Post subject: | Ticking |
I have this unusual ticking noise coming from the driver front tire. The man that I purchased the car off of did not replace this long spring/coil that went around the brake drum. Is this causing the ticking noise? I checked underneath and I can't find anything rubbing against the drum or rim that would cause this ticking. Also, can I put disc brakes on my 63? Does anybody have a link for this procedure? |
| Author: | GTS225 [ Tue Aug 14, 2007 8:02 pm ] |
Can't help you with your ticking noise problems, but here's a link to the steps for the disc brake swap. It's touted as being for '64-'76 A-bodies, and I can't say for sure if it'll work for a '63. Dan....you care to add anything? I'm not up on swappability on the narrow body. http://www.bigblockdart.com/techpages/d ... sion.shtml Roger |
| Author: | SlantSixDan [ Tue Aug 14, 2007 8:28 pm ] |
The springy coil around the brake drum was an anti-squeak measure, and its absence isn't causing your ticking. If your car has full wheel covers or trim rings rather than just centre caps, the covers/rings often set up a heck of a "ticka ticka ticka" racket. Try removing the wheel covers and driving around to see if that's it. If not, it'll be a good idea to open up the brakes and see what might be rubbing. Lots of ways to put discs on a '63. You'll need 14" wheels and some idea of your priorities in terms of stopping power, budget/cost, willingness to change over to the large wheel bolt pattern front and rear, etc. |
| Author: | Charrlie_S [ Wed Aug 15, 2007 1:16 pm ] |
Another possibility for the "ticking" is the cotter pin for the spindle nut hitting on a dent in the hub dust cover. |
| Author: | 63mopar [ Wed Aug 15, 2007 7:23 pm ] |
I took the wheel and drum off tonight and re-greased the everything. I put that spring that went around the drum back on and I still have it. That's no longer a problem with me anymore I have transmission issues now... |
